07-01-2010, 11:21 PM | #1 |
fuel pump advice
i'm looking to replace my fuel pump while i have my front clip off (might as well).
right now i have a standard AC delco pump with two rubber lines and one hard line up to the carb. i want to put an Edelbrock preformer pump on since it puts out a lower psi. this way i won't need a fuel pressure regulator for my edelbrock 1406 carb. butttt....the edelbrock pump has one inlet and one outlet...how can i make this work? thoughts? http://www.summitracing.com/parts/EDL-1721/
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
07-01-2010, 11:29 PM | #2 |
Re: fuel pump advice
So are you saying how can you make it work with "with the two rubber lines" ???
07-01-2010, 11:39 PM | #3 |
nah, the my stock style pump has what seem to be two inlets, and one outlet. the edelbrock has one inlet and one outlet. how can i make it work?
07-01-2010, 11:44 PM | #4 |
Soooo, do you have dual fuel tanks? I am wondering if you have the 2 lines, one coming from each tank???
07-01-2010, 11:48 PM | #5 |
i do have dual tanks, so maybe it is one front each tank? i'm not sure, i'll have to go trace them back
07-02-2010, 12:10 AM | #6 |
If it is, just get a Tee fitting and you're golden...
07-02-2010, 08:28 AM | #7 |
The larger of the two is the feed line and the smaller is a return line. The two port (in and out) pump will work. Just block off the return line.
Mike |
07-02-2010, 09:32 AM | #8 |
Yup the smaller hose on the inlet side of the pump is just a return. just plug the line and call it good. The bigger 3/8's line is the fuel feed.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-02-2010, 12:23 PM | #9 |
thanks guys
