Old 07-02-2010, 12:03 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Should i have primered my motor?
Fresh out of the hot tank i painted my motor with some cheap primer. Then i was planning on hitting it with 500* orange paint. Heres some pics
of what im using.
Ive heard both, dotn use primer, use primer.
Should i scrape the primer off and do striaght paint OR get a better primer? Ive got too much $ in this to half do it and have it flake off in a month.
Thanks!
should i have used the etching primer on the block? Someone help me I dunno what Im doing thanks!!
John
1999 Toyota Tacoma 4x4
Old 07-02-2010, 01:10 AM   #2
vectorit
What?
vectorit's Avatar
Re: Should i have primered my motor?
I've done a few engines, and I have never used a primer spray before applying the engine paint. Just the high heat engine enamel paint. Never had an issue with it "going bad" in one way or the other.
Personally, I'd be worried that the cheap or non high heat primer would cook off in the hotter areas of the engine. Maybe not flake, but burn the engine paint to a brown color or something of the like.
Just my .02
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-02-2010, 01:22 AM   #3
GruntMoanCough
GruntMoanCough's Avatar
Yeah, you've got a high heat engine enamel but, the primer isn't high heat. i think the primer will burn off in places and in turn the top coat will fail.
Probably easiest to wash the primer off with lacquer thinner.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 07-02-2010, 01:28 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've never used an engine primer. Just 4 to 6 coats of Chevy Orange.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-02-2010, 01:29 AM   #5
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Just my .02
X2. Never primered an engine before. Does it say on the primer can what temps it will stand? If it were me I would clean that primer off, wash and completely dry the block then shoot it with a good quality high heat engine paint. I use VHT brand in light misty coats allowing to dry about 15min. between mists until I get a good base then spray 2 or 3 good medium coats. Let her cure for a couple of days and your ready to build some POWER. Good luck.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 07-02-2010, 03:03 AM   #6
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
spray it with mineral spirits or thinner and powerwash it off, then hit it with about 3 coats of high temp. chevy ORANGE engine enamel.
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 07-02-2010, 03:47 AM   #7
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I agree with above That is a cheap primer, If you were going to primer it I would have used Dupli-Color high heat Paint, Enamel with Ceramic Resin, Flat, Gray Primer, is designed to withstand temperatures of up to 1,200 degrees F.. then your top coat will have more of a chance of lasting long without flaking later. I just went with Por15 ENGINE-ENAMEL it hasn't flaked yet and it looks good but then again I went with their Black.
http://www.por15.com/ENGINE-ENAMEL/productinfo/EEPA/
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-02-2010, 06:59 AM   #8
matchstick
matchstick's Avatar
Wash that primer off with thinner and put several coats of the duplicolor. I use automotive acrylic enamel on all my engines. It shines like new money and seems to hold up great.
matchstick is offline   Reply With Quote
Old 07-02-2010, 07:35 AM   #9
cdowns
cdowns's Avatar
i've used duplicolor primer on engines and also just the duplicolor with no primer and have seen no difference in the final product or how long it lasts
that primer id just wipe it off with laquer thinner soaked rag or shop towels
Old 07-02-2010, 08:41 AM   #10
bigsnookmaster
bigsnookmaster's Avatar
X-2 I use automotive enamel and have had no problems at all. It cleans real easy and lasts!
bigsnookmaster is offline   Reply With Quote
Old 07-02-2010, 10:11 AM   #11
oldblue1968chevy
Ok looks like im wiping my primer off with laquer thinner and doing straight up 500* chevy orange, thin coats 15 min. between coats. Then get thicker.
Thanks guys!
PS, its got the pistons crank cam timing chain etc in it., no powerwashing lol
John
Old 07-02-2010, 10:34 AM   #12
71 super
71 super's Avatar
If you can afford it POR engine paint is the route to go. I have used all of the other spray can types and while it works ok for a while, the POR is there to stay. Leddzepp was the reason I went with POR the first time and I will never use anything else again on anything I want to look good for more than a few weeks.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-02-2010, 11:14 AM   #13
my67chevytruck
Under Construction
my67chevytruck's Avatar
Originally Posted by 71 super View Post
if you can afford it por engine paint is the route to go. I have used all of the other spray can types and while it works ok for a while, the por is there to stay. Leddzepp was the reason i went with por the first time and i will never use anything else again on anything i want to look good for more than a few weeks.
x2!!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-02-2010, 01:22 PM   #14
oldblue1968chevy
im going go have to try some of this por stuff lol everyone says its great
i got the primer off and washed it with brake cleaner let it dry and sprayed 2 cans of 500 degree orange paint.
post pics later
John
