07-02-2010, 02:37 AM | #1 |
Wheel alignment
Do I need a wheel alignment after the installation of drop spindles. No other adjustments were made to the front end, no lowering springs, just 2.5 inch drop spindles. Thanks.
"If you need to tell everyone how good you are - your probably not" |
07-02-2010, 06:19 AM | #2 | |
Re: Wheel alignment
I would, there is the possibility of slight differences in the machining of the parts. It doesn't take much to be off enough to cause tire wear, or even drifting/pulling.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-02-2010, 04:53 PM | #3 |
Active Member
Re: Wheel alignment
You should get the truck realigned. When working on new kits I like to start with 5 different trucks, align them before and after. I compare the adjustments required before making the final part. What I correct for is the deviation I see from Chevrolet, Ford, etc. They do not build the trucks that well in the first place. So yes, get it aligned when your done.
Danny Nix CPP |
