Old 07-02-2010, 02:46 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
200r4 question?
first thing im wondering is will i have to move the trans cross member if i go from a th400 to 200r4?
second i think i found a good deal on a core to rebuild...$75. is that a pretty good deal?
third what the heck is a "unibolt" 200r4?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 07-02-2010, 02:55 PM   #2
69lemans
Re: 200r4 question?
Crossmember will need to be moved back,but there should already be holes in the frame.
Thats probably a fair price for a core.
Unibolt means it has both bolt patterns for Chevrolet and for Buick Olds Pontiac
69lemans is offline   Reply With Quote
Old 07-02-2010, 02:58 PM   #3
cdowns
cdowns's Avatar
Re: 200r4 question?
its 200 4r tranny that you need
Old 07-02-2010, 03:03 PM   #4
BIGBLU 72
BIGBLU 72's Avatar
Re: 200r4 question?
okay good! i think the guy said it was out of a V8 85 monte carol so will that have the gear driven speedo?
Old 07-02-2010, 03:30 PM   #5
raycow
Re: 200r4 question?
Leave your crossmember in the TH400 position. The distance from the bellhousing face to the mount is the same on both transmissions.
I have never heard the term "unibolt" before, but all the 200-4Rs I have seen had a dual-pattern bellhousing which would fit both Chevy and BOP. That is probably what "unibolt" means.
Ray
raycow is offline   Reply With Quote
Old 07-02-2010, 03:39 PM   #6
ewoody625
ewoody625's Avatar
Re: 200r4 question?
i heard that the 200 and 700 r4 will bolt right in with no mods if you have a 400 trans
Eric
70 CST10 long bed in pieces also factory air and cruise(the project)
18 Silverado crew cab 5.3 4x4
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166
ewoody625 is offline   Reply With Quote
Old 07-02-2010, 04:04 PM   #7
cdowns
cdowns's Avatar
Re: 200r4 question?
you'll need driveshaft done as the th400 tranny has a different type of yoke
Old 07-02-2010, 04:07 PM   #8
BIGBLU 72
BIGBLU 72's Avatar
Re: 200r4 question?
i just talked to the guy about the trans and im getting it for 50 bucks! the said it was behind a 87 monte carlo with a 4.3 v6 is that goin to be a problem? im goin to have it rebuilt to a pretty stout trans but the core only has 95k miles on it so im thinking that it might be in decent shape.
Old 07-02-2010, 05:59 PM   #9
raycow
Re: 200r4 question?
The 400 is about an inch longer than the 200-4R, and as already mentioned, has a larger output shaft spline. The 700 is about 3" longer than the 200 and its mount is closer to the front.
Ray
Old 07-02-2010, 06:00 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 200r4 question?
Just be sure its a 200-4r...and not a TH-200 or TH-250!
1968–1986 TH350/TH350C/TH375B/TH250/TH250C
1976–1987 TH200/TH200C
1981–1990 TH200-4R
1982–1993 TH700R4/4L60
My 200-4r:
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-02-2010, 11:35 PM   #11
BIGBLU 72
BIGBLU 72's Avatar
Re: 200r4 question?
okay so what am i going to have to do to this trans to make it live behind a 400hp-425hp 400sbc?
Old 07-03-2010, 01:18 PM   #12
68GMCCustom
Re: 200r4 question?
mines built for 500hp or so...
Kurt -
Old 07-03-2010, 02:00 PM   #13
cdowns
cdowns's Avatar
Re: 200r4 question?
www.fbperformance.com they've been racin these for many many years over 1000hp not an unusual build for them
Old 07-03-2010, 02:37 PM   #14
mrh33916
Project '67 454
mrh33916's Avatar
Re: 200r4 question?
Coming off of a V6 you will probably have to change both the drive and driven speedo gears. Have the builder install the correct ones for your application when he builds it as the drive gear on this tranny is a part of the governor.
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 07-03-2010, 02:37 PM   #15
68GMCCustom
Re: 200r4 question?
Art Carr move to CA...but he's one of the best with 200-4R's.
http://www.cpttransmission.com/index.htm
Kurt -
Old 07-03-2010, 03:16 PM   #16
rsavage
rsavage's Avatar
Re: 200r4 question?
Lots of info on Bowtie Overdrives too along with the Buick Grand National site. Best trans came from the GN's (virtually impossible to find) and the Monte SS's. Both had valve bodies that would shift at 5000 rpms under wot. The rest (Cadalacs, Chevy's Olds, etc.) shift at 3000 rpms wot. Mine was from an 84 V8 olds and it shifts exactly like Grandpa's olds, way too smooth and way too soft. When I change engines, I will have to do some work on the transmission too. Right now with the original 307, it doesn't much matter. TV cable adjustment is critical to the 200 4R's longevity. You will need a bracket that permits the proper adjustment. Several tranny builders such as Bowtie OD's make them for specific carbs. Keep us posted on what you learn.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 07-03-2010, 07:27 PM   #17
BIGBLU 72
BIGBLU 72's Avatar
Re: 200r4 question?
im goin to build this trans to pull trailers and stuff. its not goin to be a hot rod truck. would i do better to just find a 700r4 ans build it or just stick with the 2004r
Old 07-03-2010, 11:38 PM   #18
68GMCCustom
Re: 200r4 question?
check our the ratios and see which will work best for you. I like the closer 1-2 and lower 4th ratio of the 200-4r
Kurt -
