02-17-2003, 08:14 PM | #1 |
whats wrong
when i am out and about town driving my truck, when i come to a stop sign or light whenever i apply the gas to get going the truck will sit there for a little bit before it goes and then when it goes it goes with a jolt like i have a gear slipping or something, but it only does this when i am driving slowly if i ma out hot rod'n it, it is just fine and drives with no problem any and all help would be appreciated
02-17-2003, 09:12 PM | #2 |
Cantankerous Geezer
Could be the accelerator pump in the carb. What engine and carb do you have? Real common with the Rochester one bbl on sixes.
Fred There is no such thing as too much cam...just not enough engine. |
02-17-2003, 10:14 PM | #3 |
72 Cheyenne
Transmission?
02-17-2003, 11:03 PM | #4 |
If you have done any Hot Rod stuff to the motor, you might think about a stall convertor. 5 or 600 exrta rpm might do it.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
02-18-2003, 12:33 AM | #5 |
the truck is running a 350 with 202 heads edelbrock performer intake and carb and a mild cam not sure what kind, and it has a th350 tranny
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-18-2003, 01:19 AM | #6 |
I hate to ask. Could you be low on trans fluid?
'72 GMC custom camper 350/350 |
02-18-2003, 02:23 AM | #7 |
02-18-2003, 03:48 PM | #8 |
I agree with Fred T, check the accelerator pump cup on your Edelbrock carb (Carter AFB). If they sit for any period of time, the cup will rot out and crack. As long as you keep soaking it with new fuel, they seem to last forever.
Did the carb sit for any period of time?
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454 '93 K2500 Suburban, Old 454 (157K) |
02-18-2003, 08:31 PM | #9 |
I agree.... Take a look at the accelerator pump. You should be getting a good shot of fuel into the venturi when you pump the gas.
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
02-18-2003, 08:58 PM | #10 |
sounds like trans. trouble. Chec kthe fluid level & service the fluid & filter if it hasnt been done in a while, unless the fluid is very dark & burned smelling then i would just find another tranny or get yours out & rebiuilt.
DR. LOW |
