Old 07-02-2010, 10:19 PM   #1
longbike
longbike's Avatar
57 6 lug wheels
Hey guys I just picked up a 57 chevy truck for restore project and I got a question about the wheels.
It has 6 lug bolt pattern and I was wondering if the late model 4x4 6 lug wheels will fit to these 57 stock axles or do I need to look for special wheels for this era? I want to go with Rally wheels!
Thanks for your help!
Jeff
longbike is offline   Reply With Quote
Old 07-02-2010, 10:30 PM   #2
frednoah
86 Scottsdale
Re: 57 6 lug wheels
Jeff
The late model 6 lug pattern is 6x5.5"(also referred to as 6x139.7mm) ... Not sure on your 57. If the pattern matches, they will bolt up. Actually fitting and not having tires rubbing will be more of a function of backspacing. The newer rims may have to have spacers to correct the backspacing difference.
frednoah is offline   Reply With Quote
Old 07-02-2010, 11:54 PM   #3
bobinbc
bobinbc's Avatar
Re: 57 6 lug wheels
They fit. BTDT
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 07-03-2010, 12:52 PM   #4
longbike
longbike's Avatar
Re: 57 6 lug wheels
Thanks for your help guys!!
Old 07-03-2010, 03:10 PM   #5
OrrieG
OrrieG's Avatar
Re: 57 6 lug wheels
Aren't there some center hole differences?
OrrieG is offline   Reply With Quote
Old 07-03-2010, 03:17 PM   #6
raycow
Re: 57 6 lug wheels
Later wheels will fit with no problems up to about 87. Newer than that, the bolt pattern is still the same but the center hole will be too small to fit over the hubs.
Ray
raycow is offline   Reply With Quote
Old 07-04-2010, 12:17 AM   #7
longbike
longbike's Avatar
Re: 57 6 lug wheels
Well then let me ask you this! Can I convert the 6 lug drums to 5 lug rotors "4 Wheel disc" or will the spindles have to be changed out for being different sizes?
Old 07-04-2010, 01:26 AM   #8
raycow
Re: 57 6 lug wheels
You can get disc conversions for the fronts that have 5 lug rotors and keep your stock spindles. For rear discs you will probably have to swap the entire rear axle. I am not aware of anyone who sells a disc conversion for the stock 57 rear.
Ray
Old 07-04-2010, 11:33 AM   #9
longbike
longbike's Avatar
Re: 57 6 lug wheels
Thanks Ray,
I think Ill just stay with the 6 lugs and keep it original but I do want to convert to disc brakes in front!
Old 07-11-2010, 05:29 PM   #10
bob54
Re: 57 6 lug wheels
I got set of 15 by 8 6 lug that came of my 54 3100 there off set to the outside and are for sale on craigs list metro detroit bob
bob54 is offline   Reply With Quote
Old 07-12-2010, 12:18 PM   #11
longbike
longbike's Avatar
Re: 57 6 lug wheels
Wish you were closer Bob! The shipping would kill me!
