Old 07-02-2010, 11:54 PM   #1
westie 666
westie 666's Avatar
Gauge restore
Hi all
I have spent the last few days restoring my dash cluster, I am down to painting the pointer needles in the gauges.
Can anyone tell me what paint to use? so far I have had no luck in finding any thing close to it.
Thanks in advance
Bob
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 07-03-2010, 07:43 AM   #2
RuralRoute C-30
RuralRoute C-30's Avatar
Re: Gauge restore
I recall just picking up a small can of GM red spray paint at NAPA. There are a few versions of 'red' but take your pick.
I did learn by doing that those needles are fragile when my first thought was to remove the needles to paint...I was wrong.
Was lucky to have a spare set of gauges to replace the one needle I broke when trying to remove it and left the rest alone. Took some advice from here to just slice paper and slide behind the needles to mask the gauge face when painting the needles.
Just another lesson in learning to watch paint dry between coats! Hope it helps.
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 07-03-2010, 11:20 AM   #3
72lb4x4
Re: Gauge restore
I used an orange paint pen sort of thing from a craft store. There were lots of colors...
72lb4x4 is offline   Reply With Quote
Old 07-03-2010, 11:34 AM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Gauge restore
I always used Testors orange, for model cars, you know those little bottles? As long as they are all the same color, it looks perfect.
I need to dig in and see if a white panel is better, or the chrome/silver is better. I'm seeing both on here, surely one is better than the other. I'd really think white would get a brighter cleaner light reflected.
RandyP is offline   Reply With Quote
Old 07-03-2010, 12:06 PM   #5
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Re: Gauge restore
Mark
You know... all my gauges decided to stop working.. i have an 84... same cluster set-up as you.... the Speedo squeeks and wobbles like heck... need to change that for sure.... but the fuel gauge only reads to quarter tank when full.... does the printed circuit board behind the cluster have anything to do with them not working? dont know if i should go head and get all new gauges, or start with the circuit board first... thanks in advance
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 07-03-2010, 12:13 PM   #6
RandyP
RandyP's Avatar
Re: Gauge restore
The speedometer runs off a cable alone, the gas gauge does rely on the printed circuit, but faulty gas indicator is usually a different issue. If all other gauges are working, I'd trouble shoot it a bit further first. Chances are the trouble is inside the fuel tank, at least in my experience.
Old 07-03-2010, 01:05 PM   #7
RuralRoute C-30
Re: Gauge restore
Not an expert on this but I have been there and done it. Might start at the source and inspect the grounds first and then the circuit board behind the gauges. (actually to say it is a 'board' is inaccurate when it essentially is a film of plastic)...but if you get that far you'll see this:
or in my case before I fixed it...this:
Bought this truck that once must have been a mouse house at some time in its lifetime. Always learning!
Mark
Old 07-03-2010, 11:26 PM   #8
westie 666
westie 666's Avatar
Re: Gauge restore
Thanks guys, I ended up using Tamiya flourescent red, comes in a spray can but I brushed it on, had to give them 6 coats but it has covered well. I also painted the rear reflector area with high gloss white, it has turned out very good and i can now see the gauges at night, I did replace all the sockets and bulbs even though all were working, at 2$ each it is cheap enough.
Old 07-04-2010, 02:08 PM   #9
CaliDude76
CaliDude76's Avatar
Re: Gauge restore
Mark
Right on! Thanks.. I see those circuit dealios in my ClassicParts, and LMC Catalogs.. might just go head and pick one up... how do you remove and replace those? Do they just peel off?
CaliDude76
Old 07-04-2010, 02:44 PM   #10
RandyP
RandyP's Avatar
Re: Gauge restore
The lamp sockets and such hold them in place.
