tubular control arms yeild a drop?
I have checked both CPP and PORTERBUILT and ART arms for this question. Do the arms have a drop built into them or it is the corrected camber that makes the truck lower? I am saving up for a set and wanted to know this.
Thanks Juan
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
Re: tubular control arms yeild a drop?
Our arms have an extra .5" of drop built into them.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Thanks for the reply Nate. I noticed the adjustment in your arms for the ball joint angle just was unclear of actual drop built in.
Thanks again. Juan
Active Member
CPP arms do not drop the suspension because that looses ground clearance. (we use a smaller diameter bushing so the crossmember, not the arm, is the lowest point.) We recomend uinig a drop coil, drop spindle, or both. Our upper arms have a little more caster and are a little longer so you can easily align the front end after it's been lowered.
Danny Nix CPP |
Mine drop about 1.5" from a factory arm
