07-03-2010, 12:02 PM | #1 |
Grandpa in the rustmobile...
Best spraypaint to panit alt. brackets/pulls etc?
I have my alternator brackets some pullys etc etc.
I have some bedliner stuff left over. Should I paint my brackets with those? How hot will it get? And what kind of paint (rattlecan ) Should I paint my pulls etc. with? thank you!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-03-2010, 12:06 PM | #2 |
Re: Best spraypaint to panit alt. brackets/pulls etc?
i like spraying that stuff with duplicolor enamel then i put in a 300oven for 45min or so
07-03-2010, 12:18 PM | #3 |
whata bout 'colorplace' enamel in gloss black? Will it hold up to 300* in the oven? Do I need to put a primer on it? If so what kind? I have some etching primer and just cheap 'colorplace' primer
noone is home
07-03-2010, 12:25 PM | #4 |
If It's White or Black I found Appliance paint works well. It's an epoxy and I don't believe primer is required
Or, even BBQ paint. You should be ok with the bedliner though but if you gotta buy the paint why not engine paint. |
07-03-2010, 12:30 PM | #5 |
I already have bedliner and i like how it looks/holds up
but im interested in baking the spray paint..
07-03-2010, 02:42 PM | #6 |
I had some Rustoleum bedliner lating around and shot all my stuff for my SB for my Jeep Cherokee with it I think it looks really nice...
I also used it to paint the valve cover on my Honda and it's holding up great no issues.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
07-03-2010, 02:55 PM | #7 |
Huh..Didnt know if you would hold up to valve covers..I would think it'd melt.
nice motor^ specs?
07-03-2010, 04:01 PM | #8 |
I use Krylon semi flat, that is the closest to factory color and I have never had a problem with it burning on brackets and pulleys
07-03-2010, 04:10 PM | #9 |
I use PpG base coat clear coat.1 coat epoxy- 2 coats of base-2 coats of dc3000. Over 20,000 miles on the truck, engine compartment and motor look flawless..
07-03-2010, 04:14 PM | #10 |
How do you prep primer paint them? I want durable. Thank you!
07-03-2010, 04:14 PM | #11 | |
the motor is a 69 327, Had it rebuilt a few years back Mostly stock aside from being blueprinted and balanced, and a mild cam. mostly head work SS Valves, better springs And what not. running about 350/325
07-03-2010, 04:19 PM | #12 |
Sounds about like mine, what heads?
Ok I think as of now ima paint my brackets with bedliner unless another better opinion...now gotta degrease prep more crap ew lol
07-03-2010, 04:52 PM | #13 |
202 Fuelies
07-03-2010, 06:33 PM | #14 |
i wouldnt use bedliner on valvecovers it would tend to keep the heat in i'd think. you're better off with something that allows heat to come off the valvecovers as they do aid in slightly cooling your oil
07-03-2010, 06:47 PM | #15 |
The stuff I used is essentially just spray paint with sand in it...
07-03-2010, 08:00 PM | #16 |
I used bedliner on the brackets,,not sure about the pulls yet..I dont want something heavy because its a balance blueprinted engine lol paint is heavy enough LOL
07-04-2010, 01:34 PM | #17 |
I've been liking the rustoleum hard hat paints lately
07-04-2010, 03:07 PM | #18 |
I used bedliner on the alt. brackets. I'll post pics up later. Wire wheel'd em, wiped with lauqer thinner and 1 thick coat of brush on, may put anoother one on. Happy 4th of July!!
07-04-2010, 10:13 PM | #19 |
i used some rustoleum spray from autozone and it seems to be getting the job done
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
