Old 07-04-2010, 11:38 AM   #1
Sillyoldman
#16876
Sillyoldman's Avatar
Ok now what?
I'm posting this here opposed to the electrical section because this is a year specific post. And you all are better looking over here
I've been staring at the ugly mess of a steering column on the '63 for way too long. I anticipated a battle pulling off the steering wheel. I discovered that the nut required 2/3 of a turn to remove. I figured I would need a puller to get it off but gave it a yank first. Luck I didn't break my nose! It nearly fell off. The turn signal harness assembly appears to be "ok" although the lever and the cam is mostly gone. Where do I find a new switch & Harness? It appears that everyone sells a '64-66 one but I don't see a 60-63. Should I just buy a new cam and lever and chuck it back in? At this point my electrical starts the engine, turns on the headlights but that's all I get. I figured the column is a obvious starting point.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 07-04-2010, 11:56 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Ok now what?
Your pics are a little blurry. I cant tell if it's the same as the later years or not. If you find the switch it will have a new harness.
This was my JB Welded mess.....thought I had a pic of the fresh switch....guess not.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-04-2010, 04:52 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Ok now what?
According to the GM Parts book;
60-62 and first jobs 63, canceling cam 3813945 W/ Integral spacer
63 after jobs 3831338 W/O integral spacer.
The 63 after jobs 3831338 is the same as 64 W/O integral spacer.
Now get this 3813945 is the same for 64-66. Seems like you could have an early 63 or late 63 canceling cam depending when your truck was built, the difference was a spacer that was integral or seperate.
Scan from 63 Truck Shop Manual.
Old 07-04-2010, 08:01 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Ok now what?
what I would do is change the whole thing to a 65-66, so you can get parts.
I ended up doing that with the wifes 63, I had to change the whole cup signal cam and harness, it all fit and plugged right in, the only problem is that it is now gold/silver instead of white
I had checked the wrecking yard and out of the 15 or so 63's most were broken...
like areo mentioned and I found out the interchange is :
60-62, they use a metal rod to go down to a switch in the column and the turn signal column cups will not interchange with a 63-66 column.
63 (except late 63?) all by itself, the plastic signaler has a different screw pattern than the 64-66, but the column cup will work with a 456 column.
64-65-66 all interchange. signal cup will fit on a 63 column.
Old 07-04-2010, 08:05 PM   #5
jocko
jocko's Avatar
Re: Ok now what?
LMC sells 'em. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=88
Cams and cancelling parts are elsewhere int he catalog, but 60-63 specific switches on the link. Although... I did notice 63 Chev is same part number as 64-66 GMC. Interesting. (But it is different than 64-66 Chev). But it taint cheap.
Old 07-04-2010, 09:15 PM   #6
63 & 64 Bowties
and a few others
Re: Ok now what?
But it taint cheap.
Exactly. That's why I ended up putting the chrome universal switch in my 63....http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=60
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-06-2010, 10:16 PM   #7
Sillyoldman
#16876
Re: Ok now what?
Thanks all for your efforts in helping me. Very good info. Until now I was not even sure what I was looking at because it appeared to be nothing more than a broken up mess. I think I'll start with a new cancelling cam and lever.
