02-17-2003, 10:13 PM | #1 |
tach differences
Does anyone know if there is any difference in 6 & 8 cylinder original tachs? Someone told me once that you can make them work on either.
Thanks |
02-17-2003, 11:27 PM | #2 |
D.U.F. Member
I don't know about your tach question, but it's good to see another South Dakota member on the board. There's not a whole lot of us. Just wanted to say hi and welcome to the board.
MEMBER OF THE DISCS UP FRONT CLUB '72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt '68 C-10 4spd (not running) '79 C-10 LWB Mild 350 '80 Caprice Classic, 2-dr '97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto |
02-17-2003, 11:29 PM | #3 |
jeffbo, I see your from watertown. I was there a couple of years ago at the terex plant for some training.
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
02-18-2003, 12:12 AM | #4 |
Roadtrip!
6 or 8
As far as i know they are not interchangeable. The readings will be inaccurate. If there is a way to change them over, i am not aware of it.
02-18-2003, 02:23 PM | #5 |
The 6 cylinder tachs can be calibrated to work on 8 cylinder engines. If you look on the back, there is a taped up hole for calibration. Just hook the tach to an engine along with a known tach for comparison and adjust it at various rpm's.
Jim |
02-21-2003, 01:52 PM | #6 |
This hole.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
02-21-2003, 02:01 PM | #7 |
That's it!
Nice pic. Jim |
