![]() Join Date: Jun 2008
Free stuff
Cleaning out the shop. You can have any of the following for free - just come pick it up. No shipping as these are big, heavy pieces:
- 67 12-bolt 6-lug coil spring - I believe it is a 3.73 non-posi. - 67 front crossmember - I have the upper and lower control arms boxed up - you can have those too - 67 2-piece driveshaft |
Re: Free stuff
Do you have a photo of the upper A-Arm mounting brackets (are they rusted out?)
Thanks |
Re: Free stuff
Are you asking about the studs on the crossmember where the upper a-arm cross shafts mount? Those are not stripped or rusted out. I was able to remove the nuts from them with some WD40. If you are asking about the area where the cross shafts screw into the upper a-arms - they aren't stripped but they are certainly aren't smooth - I don't think I'd chance it myself.
Re: Free stuff
TTT - no takers?
Re: Free stuff
Dam I would take the DS and axle.
Your too far away...
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
Re: Free stuff
if you still have any of this stuff I'll take all of it, or at least the axle, I live in Tomball, let me know when's a good time to come.
'68 C10 LWB 6.2NA/NP833 3.73's |
Re: Free stuff
I do still have it. When would you like to pick it up? I'm home after 6 each day during the week.
Greg |
Re: Free stuff
I can pick it up this evening
'68 C10 LWB 6.2NA/NP833 3.73's Last edited by 1968CHEVYC10; 07-20-2010 at 12:33 PM. |
Re: Free stuff
Great. My address is 35803 Post Oak Circle, Magnolia, 77355. If you'll give me a call at 281-513-1076 when you're on the way I'll have our gate open when you get to the house.
Thanks. |
low n' slo
![]() Join Date: Mar 2009
Re: Free stuff
ill take the crossmember if its still available
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Re: Free stuff
The crossmember is still available. When would you like to pick it up? I'm in the Magnolia area just north of Tomball off of Hwy 249.
low n' slo
Re: Free stuff
I can grab it tomorrow. is it rusted up anywhere, besides surface rust? and is it a direct replacement for my 67 suburban?
#13 |
Re: Free stuff
Tomorrow I'll be gone until around 7 and then around all day Sunday. It's got quite a bit of surface rust - it doesn't appear to be anything more than surface rust. It was off a 67 donor SWB pickup - I don't know if they are the same for the burb.
