Old 07-04-2010, 04:49 PM   #1
trenchwarfare
Cruise Control!?!?!?
What is the cruise controls setup supposed to look on my 1990 tbi 350 suburban? I believe I'm missing quite a bit.
____________________________________
trenchwarfare is offline   Reply With Quote
Old 07-04-2010, 08:31 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Cruise Control!?!?!?
Go aftermarket. Stock unit used vacuum. An aftermarket unit from www.rostra.com can be either vacuum or electronic. I have one installed on my truck. It works great. Worth every penny.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-04-2010, 08:51 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
90 burban... should have a VSS output on the trans... grab a cruise control module from a 99+ newer pickup/subrban and call it good. I wired that same module in to my factory switch no problem. just needed power, grounds and a few extra connections and voila - cruise control. the VSS output from a 90 burban and my application shouldnt be any different.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
