Fuel filter wont stay full?
66 short step, rear stainless tank, elect inline pump,runs great for hours and then engine dies, the fuel filter will be emty and the pump is running, or at least humming. let it cool for 5 mins it will slowly put fuel in(not fill) the filter and run fine. Any thoughts guys?
Re: Fuel filter wont stay full?
Didn't read it all... disregard.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. Last edited by bglad420; 07-04-2010 at 08:28 PM. Reason: I'm a dork |
check the feed from the tank @ the tank. disconnect the line that feeds your fuel pump& put a little air pressure to it to blow it out. just did this to my fuel tank. same symptom to the tee. funny thing is its a brand new tank with a little debris in the pick up tube! @ no extra charge! lol, took me 1500 miles to figure this out. best of luck, Pat ps, make sure your vent is open and not clogged. now the fuel filter is full of fuel& she runs like she should. cheers, Pat
where is your fuel pump in relation to the tank?
What kind of electric pump is it? A small Mr gasket / Bosch parts store special will do this when it gets hot. Mine did this and I replaced it with a good Holley Red and have not had a problem since. Just road tripped it to the beach ( not too far about 45 miles one way) and ran great no problems. Before it acted like it was vapor locking.
Slowly but surely getting it done. |
Resistance is Futile
I agree with the others; junk in the tank or the pump.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
The strainer on the pickup tube in the tank has a micro screen on it...it sounds like it is clogging while the pump is sucking fuel from the tank and when the engine dies/starves, the sediment settles from the strainer and the engine will start again. The fuel filter will not be full at any time, but fuel will flow.
I had the same issue on a '64 GMC, so I removed the strainer from the pickup tube and installed a fuel filter between the fuel pump and the carburetor. The truck ran like a champ after this change. |
Mine did the same thing,pump was under the hood on firewall across from were the stock pump mounts on block. After doing some reading on this forum i learnd that most electric pumps are ment to push not pull fuel, so i mounted it as close to the tank as i could and haven't had a problem sence.
#9 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
Have 2 Fuel Filters on mine, manual fuel pump, and will be getting a electric fuel pump installed in the rear for start ups from Jegs...
Extra Loud electric fuel pump! http://www.jegs.com/webapp/wcs/store...tric+fuel+pump Yea...... Just gotta troubleshoot the fuel system there bud.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 07-19-2010 at 11:56 AM. |
#11 | |
It's Better With Nitro
