2WD Jimmy
![]() Join Date: Mar 2005
4150 throttle linkage
Anyone running a 4150 Holley? What are you running for a throttle linkage? Cant seem to get the secondaries to open with the stock cable.
My Carbon Footprint
Re: 4150 throttle linkage
You can get a 4150 in both vacuum and double pumper, also most are DP's. If you disconnect the linkage, can you get them to open up by using your hand? Think we need a little more info. You can get them to open up just fine with the rod style or cable. I am using both. Must be a geometry issue. Pics of what you are currently trying would help so we can see where you have it hooked to the carb.
#3 | |
2WD Jimmy
Its a mechanical secondary 925 blow through application from the Carb Shop. Yes, I can open it by hand. Im hoping to use the stock cable, and pedal as I hope you can see in the pics. Im using a Jegs adjustable bracket, but Im thinking maybe the stock bracket would be a better choice? Anyway, the way it is now, it ony goes far enough to open the primaries. My Cobra buddy says, "Hey, thats a great govenor!" ![]() Sorry, the last pic is fuzzy... TIA, Tom |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I would say you need to move your ballstud forward to the hole in front of where it is now.
Ball stud needs to be where return spring bracket is now.
1970 c-10 short/step box morphing into street/strip 1967 RS/SS convertible Camaro 1932 Henry Ford steel 5 window coupe highboy hotrod 1931 full fendered model A sedan AV8 traditional hotrod. 1934 Ford 5 window coupe and a (pile-of-parts) 1929 Model A coupe, plus our "normal" people vehicles. |
I agree had the same problem with the same bracket on a friends truck.
Justin weight 3480 with driver 1.35 60ft 6.13@111mph 1/8 mile 9.80@131mph 1/4 mile 434 small block all motor |
#7 | ||
2WD Jimmy
OK then, should I do away with the Jegs bracket altogether and use the original factory bracket and just depend on the spring on the carb? |
60-66 Nut
It's been my experience that vehicles with mechanical linkage use the large upper hole where you have your return spring now. Vehicles with cable linkage typically use the hole below and rearward, This is where the ballstud should go. Do you have enough cable left to move the ballstud forward? I've not used the Jegs throttle cable bracket, so I don't know what to say about that. If it is restricting sufficient throttle opening, it may need to either be modified or replaced.
I would leave the return spring where it is for now. I just had a thought....are there different throttle cables for these trucks with a small block versus a big block?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-06-2010 at 11:17 PM. |
At the body shop.
Another thought, two return springs? On different note i used to work around the corner to the carb shop sure heard some great music from their dyno..
" That didnt make it any newer " " Dont antique the equipment " |
#10 | |
My Carbon Footprint
They make little brackets that can bolt down to the rear stud and allow you to hook a return spring to the bottom of the linkage as Captfab suggested. I like them because it's much cleaner looking than having a big ole spring going to your radiator and the front of the carb. ;o) I have an old tow rig that I didn't really care about looks and I actually had to bend the bent part of the primary bracket straight that is used for an A/C fast idle solenoid and drill a hole in it for my ball stud. Gave me enough throw for full throttle but looks kinda hillbilly! ![]() |
