resto body guy
tbi questions?
hey guys i finally got my tbi motor in my 71 super now i got questions...
i have a good 87 c-10 computer wiring harness all the way back to fire wall inside the firewall is where the 87 got all burnt up. so basically have the compter harness and that is it! how can make this with out spending 400 dollars for a painless wiring kit? can i plug this into the stock 71 wiring?? if not would it be smart to snag another dash wiring from a 73-87 truck? i have got all my fuel pump and etc. figured. i just need advice on this part! i'm trying to do this low buck as my funds are tight. thanks, David |
Re: tbi questions?
you need the complete wiring harnesses for both. all you need from the tbi truck is the engine harness and computer harness. the power feeds/ box and lighting will be kept from the 71 harness, unless you want a modern style fuse box.
resto body guy
Re: tbi questions?
the computer and engine harness are the same loom the fuse panel and all the fuses ect is the under the dah and which got burnt from my 87. just trying how to figure this out on how to wire it in and have everything work.
#4 | |
Still plays with trucks
Re: tbi questions?
I am planning on using the square body tilt column with delay wiper / cruise on the turn signal control stalk too. I'm sure it will take some fabrication work but I will make it fit. Just need to figure out where to put the check engine light so it doesn't look out of place.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Re: tbi questions?
