Old 07-05-2010, 01:06 AM   #1
bigkahuna327
Alternator Bracket for SBC with headers
I'm trying to change my 327 SBC over to run a set of headers and I'm running into a slight problem.
Currently my alternator is located on the drivers side with the top bracket connecting to front of the intake manifold and the lower bracket bolting into a boss on the front of the stock exhaust manifold.
With the headers I will no longer have a place to mount the lower bracket, and since my 327 has double hump heads, there is no place to bolt a traditional lower bracket into the front of the head.
Does anyone have a suggestion, part numbers, or can tell me what brackets may work to convert this over without switching everything around and using as much of my current setup as possible?
Thanks,
bigkahuna327 is offline   Reply With Quote
Old 07-05-2010, 10:26 AM   #2
71 super
71 super's Avatar
Re: Alternator Bracket for SBC with headers
I have used the "step bracket" sold by mr gasket that mounts to the front header tube bolts and the "u" bracket that the sell to get the pivot point for the bottom of the alt. and the 66-68 chrome 327 solid bracket they sell to get the upper slider. It works ok. My 68 had a homemade setup that used the original brackets coupled with a strap made from a piece of steel that bolted to the block at the location of the power steering mount. Luckily it did not mess up the original bracket and it worked ok, but not pretty. I did not take pictures it was that bad, go with the mr gasket stuff and you should be ok.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
