Old 07-05-2010, 07:00 PM   #1
Bullseye54
Just a little screw......
...........the one that goes under the wing vent on a 72 door that is. My pass door has a 72 door shell & I need the screw & the ferrell that goes with it,I'm also going to make the driver side match so I need a set. I found them somewhere but I can't remember where I found them. Anyone seen them online or any ideas. Next step is making some,or give it a shot. Thanks Bob
1967 C20 Custom - 396/TH400
1968 GMC short step-350/M21
Bullseye54 is offline   Reply With Quote
Old 07-05-2010, 10:54 PM   #2
Bullseye54
Re: Just a little screw......
No suggestions on where to look? Any suggestions/ideas on what to use to make the ferrell out of? Is it a sheet metal screw or is it a tapped screw,mine had a regular sheet metal screw in it. Anyone?...............Bob
Old 07-05-2010, 11:31 PM   #3
dan42
dan42's Avatar
I could use a set of those as well. You might post a WTB in the parts dept. Otherwise, I sympathize with you and here's a bump for you.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
