07-05-2010, 08:43 PM | #1 |
Bed Angle Pieces
I am currently taking the wooden bed out of my 67 stepside. Everything was going good untill I tried to remove the two angle strips at the sides. I have all of the screws out from the bottom and the stripes in the middle just came right out.
What am I missing? Do I have to take the back fenders off, are there screws holding the angle pieces to the sides of the bed that can't be seen? Need help, Thanks, Guy |
07-05-2010, 09:07 PM | #2 |
67-72 parts collector,…
Re: Bed Angle Pieces
I believe they are spot welded to the bedsides.
07-05-2010, 09:44 PM | #3 |
I agree...i beleive they are welded on.
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
07-05-2010, 09:46 PM | #4 |
Nothing to see here.....
confirmed. welded
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
07-06-2010, 10:10 AM | #5 |
Thanks guys,
Went and got a couple of grinding wheels for the drill. My idea is to grind down untill I can locate the welds and than drill them just enough to make them release. Most are hinden under the rear fenders so I may be able to pull this one of. Guy |
07-06-2010, 10:15 AM | #6 |
Do you think you will have to take the fenders off? I am looking to do the same thing and don't want to take the fenders off.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
07-06-2010, 10:22 AM | #7 |
They are welded every 3 inches. I use a 4" electric angle grinder and it is still a bear to grind all of them flat.
See this thread for finished stainless replacement. http://67-72chevytrucks.com/vboard/s...d.php?t=404835
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
07-06-2010, 06:21 PM | #8 |
Hey Everyone,
I have one angle strip out and all of the other wood except the other angle strip on the passengers side. It's has been easy. I started yesterday and have done ok so for. I built two blocks the same height as the front two braces and bolted them in place to support the bed's front body panel and bolted the back end one bolt on each side. I'm going to restore the frame under the bed now that it is open and easy to get to. My wood is teak. I ordered 'Sikkens Cetol Marine Gloss' yesterday. I'm going to get the other angle strip out and get my wood ready to refinish. Don't you just love it! Guy Last edited by Guy58; 07-06-2010 at 06:22 PM. |
07-08-2010, 07:57 PM | #9 |
Here are a few of the frontend.
07-08-2010, 07:59 PM | #10 |
Here are a few of the bed work in progress.
07-12-2010, 09:28 AM | #11 |
A word to the wise, if you are planning to replace the angle pieces in your wooden bed. The two right angle strips have tack welds most of the way along the angles. But the 6 to 8 inches closest to the the truck cab have a straight weld and must be cut free. I used a cuting wheel but the heat burnt the paint on the outside of the bed between the rear fender and the front of the bed. This turned out to be a more difficult project than I had anticipated.
Just a heads up for some of you, Guy |
07-12-2010, 03:34 PM | #12 |
Got the other angle piece cut free and went down to the local high pressure car wash. Cleaned my frame up and am waiting for Eastwood's rust encapsulator to refinish it. After I get the frame it will be back to the bed refurbish project. Funny how one thing can lead you down roads you hadn't even thought of!
Guy |
07-24-2010, 11:09 AM | #13 |
The angles I used just clip over the old one and bolt on. That was the best way to go if your building a driver.
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
