Old 07-06-2010, 07:03 AM   #1
Todd68Chevy
Todd68Chevy's Avatar
Brakes on 68 Differential and 72 Differential
I am sure this question has been asked before but I have not found an answer so here I go asking again. I have a 1968 6 lug that has new wheel cylinders and good brakes. I am getting ready to swap out to 72 front crossmember and 72 rear differential. I have found out something is different between the two rear ends but I am not sure what.
My questions are: Can I swap the 68 backing plates, wheel cylinders and shoes to the 72 rear end?? Can I buy 72 drums or redrill the lug holes on my 68 drums?? Thanks for your help in advance
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 07-06-2010, 04:57 PM   #2
raycow
Re: Brakes on 68 Differential and 72 Differential
The only difference I am aware of (besides the bolt pattern) is the overall width of the housing and shafts. If both rears have the same width brake shoes, I can't think of any reason why the parts shouldn't swap.
As for re-drilling the drums I have never tried it. Check the center hole size first, because the drum centers on that, not the stud holes. I think at least one of the new stud holes will overlap the old pattern, but the drum can't go anywhere as long as the wheel is bolted up tightly.
Ray
raycow is offline   Reply With Quote
Old 07-07-2010, 06:39 AM   #3
Todd68Chevy
Thanks raycow, that is what I was hoping but I was not sure. I thought if I could use the backing plates, shoes and wheel cylinders I might buy 72 drums and not mess with redrilling.
Todd
Old 07-07-2010, 10:38 AM   #4
SCOTI
SCOTI's Avatar
I had 'new' brakes on the rear of my 68 when I did the 5-lug swap. I swapped in new Moser axles & used local auto parts supplied Wagner 71-72 5-lug drums w/my existing set-up. You should be able to swap the parts over to the 71-72 axle you have (I don't think there's a need to swap the backing plates either).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-07-2010, 01:42 PM   #5
b&a72
Active Member
b&a72's Avatar
I am thinking of doing the same thing but the opposite, I am going from a 72 rear to a 67 rear. The 67 has 6 lug and the 72 5 lug can I just pull the axle shafts out of the 72 and put them in the 67 rear?
b&a72 is offline   Reply With Quote
Old 07-07-2010, 01:49 PM   #6
b&a72
Active Member
b&a72's Avatar
Nevermind I guess I answered my own question. I don't want to thread hijack but does anybody know what spline axle shafts a 67 has and where to get some online?
Old 07-07-2010, 02:36 PM   #7
SCOTI
SCOTI's Avatar
67 housings would have 30-spline axles.
For a 71-72 12-bolt 5-lug to 6-lug swap, I would try 73-87 12-bolt 30-spline 4x4 axles.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-07-2010, 03:21 PM   #8
b&a72
Active Member
b&a72's Avatar
I am doing the 6 lug to 5 lug swap would this still work? And are the axles the same length as the 67 axles?
Old 07-07-2010, 03:32 PM   #9
SCOTI
SCOTI's Avatar
No, it is not the same. 71-72 housings/axles are the same width as 73-87's. Pre-71 housings/axles are .750" shorter each side. If you have an OE 6-lug housing, you'll need to buy replacement axles (CPP, ECE, Moser, etc...); weld, machine, & re-drill your existing axles; or swap a later 5-lug housing into place (71-72 direct swap for coil suspension; everything else requires possible spring mount mods).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 11:55 AM   #10
Todd68Chevy
Once again a lot of good information. Thanks everybody
