07-06-2010, 10:42 AM | #1 |
Source for new steering gear box?
My steering box is trashed, no room left for adjustment, and has a blown seal.
I want to replace it with a variable ratio box. I know better than to buy some sh**** reman from Vatozone. Who do you recommend? Also I read that some rebuilders don't replace the gears. I have a hard time seeing how the gears should be reused, as I bet the ones in my box are trash. Thanks.
1969 C10 Stepside, 350ci, 700R4 |
07-06-2010, 10:47 AM | #2 |
Re: Source for new steering gear box?
Wes @ Classic Hearbeat sells an awesome unit....Its the Readhead brand...super high quality quick ratio units that are remanufactured (not rebuilt)....there's a huge difference!
http://www.classicheartbeat.com/67-72_chassis_2.htm http://www.redheadsteeringgears.com/Index.html RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 07-06-2010 at 10:48 AM. |
07-06-2010, 11:53 AM | #3 |
What huge difference? IMO, reman is rebuilding, just on an assembly line, plus spray paint. Not that I care, either a proper rebuild or reman is fine.
Redhead says they put bearings in and custom fit the gears. I mean I assume they would put some "pretty good" gears in, but anyone out there that does new gears? Also I don't see any variable ratio stuff on their site. I don't want a quick ratio in my truck. "Machining out the housings and installing needle bearings Flamespraying or replacing the shafts as needed Installing new control valves on some applications Custom fitting each worm & piston assembly with special ordered, precise oversized ball bearings
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 07-06-2010 at 11:54 AM. |
07-06-2010, 12:00 PM | #4 |
Here's a source.....http://www.agrperformance.com/catalo...ts.php?cat=101
07-06-2010, 12:26 PM | #5 |
Looks good. Where did my post go?
These guys have a new GM variable box for $295. http://www.corvettesteering.com/truck_gears.htm Found them on ebay also, but they say the 67-79 trucks have SAE fittings and the newer box is metric, requiring adapters. Grrr. Who knows, maybe I have metric lines, I doubt this truck came with power steering. Seems like there's gotta be a reman cheaper than that with more new stuff.
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 07-06-2010 at 12:41 PM. |
07-06-2010, 12:31 PM | #6 |
What were variable boxes used on new? Sounds strange that the "NEW GM" box would be different inside than what I already have.
07-06-2010, 01:26 PM | #8 |
07-06-2010, 01:39 PM | #9 |
Ok, my bad, I guess the Redhead site is a little lacking. I see they have variable boxes at classicheartbeat.
$300 plus $75 core. http://www.classicheartbeat.com/cata...ing%20Gear.htm "***Note*** A core charge is added to all sales of Remanufactured Steering Gears. The core charge will be refunded if a rebuildable core is provided to us within 30 days of the purchase date. A rebuildable core will have no excessive ware, nor be disassembled. No worn, broken, scored, damaged, cracked, frozen or rusted housings. Also No broken or damaged mounting points." Hmm, yeah I'm thinking my steering gear has excessive wear, which is why I'm replacing it. With my luck I'll pay $30 to ship it to them before finding that out I'm not getting $75 back. Also on Redhead's variable ratio box, it says quicker ratio gears were installed... I also read on chevelles.net that there are 3 different fixed ratios and 3 different variable ratios from GM and Jeep on these. What ratio box are you guys using and would you do it differently the 2nd time around? I'll pull my original gear and see if it has metric or SAE fittings, nothing on this thing is original. That new GM variable box at $295 is looking pretty good right now.
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 07-06-2010 at 01:45 PM. |
07-06-2010, 01:53 PM | #10 |
07-06-2010, 02:55 PM | #11 |
Tried calling Wes to help decide on this box vs. new but I guess he's out of town until Thursdayish. Damn.
07-06-2010, 03:08 PM | #12 |
Called the guy with the NOS GM variable boxes.... 12-16 ratio.
These are 79-up boxes with metric ports, and also he says GM reduced the input shaft from 13/16" to 3/4". So if I have the 13/16 shaft I'd have to get a new rag joint section for $50 or from a junkyard to use with his box, plus adapters for the metric for another $10. Feck. I'll have to take a look at my setup before I do anything and see what the previous owner put on there, if it's metric oring vs standard flare, and what steering shaft size. Should have known this wouldn't be easy!
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 07-06-2010 at 03:11 PM. |
07-06-2010, 03:27 PM | #13 |
Red Head can custom built you a box too.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
07-07-2010, 01:30 PM | #14 |
I guess I'll go with the Redhead variable ratio. Less dicking around making the newer box fit, and all the feedback has been good. I just hate to think my core might not get refunded.
07-07-2010, 01:59 PM | #15 |
Factory Strippers Rule!
I wonder if I could get my manual steering box rebuilt with a quicker ratio?
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
07-07-2010, 05:19 PM | #16 |
Whats the difference in the 69-72 Power Steering boxes as apposed to a 67-68 steering box? (Wondering about putting power steering on my 67)
07-07-2010, 05:38 PM | #17 |
Been running a redhead for about 3 years. I would highly recomend them!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-07-2010, 06:25 PM | #18 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-08-2010, 12:41 AM | #19 |
OR... you could get steering box out of a 77 c10. They are not too pricey, they bolt right in, and they're a variable ratio box.
07-08-2010, 07:10 PM | #20 |
Yeah, but then I'm back to gambling on used parts. It's almost impossible to find those pickups in the parts yards down here, most of the cars are 90+.
So I just forked out $340 for the Redhead with shipping.
07-08-2010, 07:53 PM | #21 |
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
07-09-2010, 03:43 PM | #22 |
Well... I was talking about a new '77 unit from the auto parts store. I think they're about $80-$90.
07-09-2010, 04:34 PM | #23 |
New Member
I also went with Redhead and am happy with the product and service.
07-09-2010, 10:39 PM | #24 |
07-10-2010, 12:31 AM | #25 | |
BlahBlahBlah
Now I have an expensive door stopper. No one wants to pay over 200 bucks for a manual steering box lol. Like others have said though, Ive heard nothing but good stuff bout Redhead. |
