progress pics
We are doing a mild chop on the top. The windshield won't be cut.
outside
the cowl is shaved and being welded on.
some work on the floor.
Senior Moment
![]() Join Date: Mar 2002
Nice, I'll be lookin to see this one as it goes along. Keep us posted
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Brad what are you planning to use for wipers? Pics look good.
Dreams are free
BRAD,
Thats how I'm gonna do mine, and take the hieght out below the rear window, to bring it down even with the side windows.. keep those pics coming...
'68 swb fleetside originally w.i.p '68 member since 1-01 w.i.p = ( work in progress ) |
![]() Join Date: Aug 2001
Brad2 - are you basically laying back the windshield to accomplish the chop? if so how much did you go back? I really like the layed back look, gives the trucks a sleeker "modern" look.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
That is how you can do the chop and I think thats how you do it there was a chop step by step in Classic Truckin Jan 2000 Vol 9 No. 13 They layed the windshield back 2 " and removed 1.5 out from under the rear window. Pretty cool thought of doing it to my truck but too much time I want to drive the truck this Summer. I can aways do it to another cab this winter then swap cabs.
Brad what do plan on using for side glass ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Fabricate till you "puke"
Yes, layed back does look more "slippery" ! How much are you dropping the top? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
The chop is about two inches. The windshield was laid back seven degrees. My alltime favorite chop is the one on the Traders 72 chevy back in the early 90's? Not so much of a chop that it is out of proportion. I didn't really want to do away with the wipers but it will make that area look so smooth. The truck won't be a daily driver so I will rely on RainX to get me by. The side glass is being done locally for me. It will be one piece side glass and won't have the filler plate that the kits have. It takes some engineering but it will work.
Good job
#13 |
So Many Ideas, So Little Money
how are yougonna bolt the back of the fenders on???
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
#14 |
Member since 2000
man i can't wait till the body work get started on my blazer.....i found more rust today
![]() how are you going to put the fender back on her??? |
#15 |
Fenders........opps!
#16 | |
14.1 @ 96MPH
I'll have to ask him where he got the front fender at least...it would explain why the eyebrow has never really fit that well.
Project1970 - LS1 Swap Complete! ![]() |
#17 |
KEEP ON TRUCKING
cool keep us updated
72 cheyenne 2wd lwb 71 k20 sons bassett va |
#18 |
very interesting. havent seen the mag article. how bout showing some pics of where to cut the top off. would like to see progress and finished photos. good job.
#19 |
Well it looks d@mn good. Keep us posted on the side window you were talking about, I want to see how you did this mod. Keep it real.
Brandon |
#20 |
i would love to see where you cut the top
