02-18-2003, 02:12 AM | #1 |
lowering question
O ke Im putting 2in spring on the front do I have to use a shorter
shock or can I use stock ones? Will I have alighnment problems becuse I'm useing springs and not spindles? If I aim I might not lower it till I can afford spindes. I did a seach to answer this but it was not cut and dry one way or anther so I realy would like to her from someone that either dose this for living or has first hand experince with this. thanks Moose
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr 7I JIMMY 350 4speed daily driver/next prodject 99Yukon wifes Last edited by moose; 02-18-2003 at 02:17 AM. |
02-18-2003, 03:08 AM | #2 |
Low & Slow
Moose, I have 2 inch drop springs on mine. I used some standard length shocks on my truck although I haven't had any problems I would go ahead and opt for the lower shocks, they aren't very much more in price from what i've seen in magazines. I haven't had any noticible problems with my alignment. I've had the 2 inch drop springs in for a year now and the tires seem to be wearing evenly. I hope this helps out some.
70' C-10 LWB Fleetside 4.5/6 drop |
02-18-2003, 10:17 AM | #3 |
I have order, but not received yet, front shock relocator from Tuner. They put the top shock mount in a much better position and move the mount point up 2 inches. The white dot on the pic is the approximate location of the stock top shock mount 42 bucks plus 8 bucks shipping.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas Last edited by Frank_Zeller; 02-18-2003 at 10:20 AM. |
02-18-2003, 11:04 AM | #4 |
Senior Moment
Is there a web site for Turner, I'd like more info on this .
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
02-18-2003, 11:25 AM | #5 |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-18-2003, 12:20 PM | #6 |
Gotta Startem Early
They do not have alot of info on the web site and they yet to have any type of magazine with more elaboration on thier stuff. I have been talking to them about a coilover system for the front though.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
02-19-2003, 01:40 PM | #7 |
Another place to look is Early Classic Enterprise. They have complete kits and are seemingly competent when it comes technical questions.
Try www.earlyclassics.com
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
02-19-2003, 02:28 PM | #8 |
70 longbed is right, the guys at Early Classic know what they are talking about when it comes to our trucks. I have never been to Turners because they are a brand new company, but Early Classic is a cool place to visit. They actually make all there own parts, and they have been around for over 10 years. Thats the reason I bought their entire lowering and disc brake kit. I couldn't be happier, it rides and stops like a new truck.
02-19-2003, 02:50 PM | #9 |
lowering
spindles have no geometry affect on a truck all they do is raise the mounting of the wheel itself i happen to have used both a 3.5 inch drop spindle and 2 inch spring still using the stock shocks with no prob...although speed bumps at a fast speed put a big dent in my lower control arms but if i had to do it again id use spindles and control arms and have nothing to do with the clearance on shocks or anything everything should all bolt up theese just change the location of the wheels themselfs....hope this helps...Steve
