Old 07-06-2010, 06:36 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Never seen this before, need advice
Hi all, while running the blazer yesterday, I noticed that I had oil leaking from the drivers side valve cover. Its in the middle of the vertical inboard side of the valve cover. Put my finger on it and its the rocker touching the valve cover and pushing oil thru it! Is the valve cover on backwards? Its the strangest thing I've ever seen. Its doing it in about 3 places all along the length of the cover. This is the cover that has the oil fill cap and PCV valve in it. Oil filler is in the front. Any advice welcome. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-06-2010, 08:49 PM   #2
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Re: Never seen this before, need advice
Hmmm...trying to figure this one out. Are you saying the rockers are knocking against the valve cover? Is oil leaking out anywhere other than at the gasket? If it's got roller rockers, you'll probably need to get taller valve covers. I imagine it's possible to mount them on backwards, but I'm not sure so there could be a clearance issue with the baffle in the valve covers.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 07-06-2010, 09:22 PM   #3
red71cheyenne
Back in the sticks
Yes, the rockers are hitting the inner side of the valve cover and oil is coming out. The gasket itself is not leaking. Its coming thru the metal!! The rockers are mounted correctly, they are just stock rockers. I'm thinking that I have the valve cover on backwards and its too close.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-06-2010, 09:33 PM   #4
vectorit
What?
vectorit's Avatar
I know on my OEM 327 valve covers, they are right/left side specific to a certain degree. Since there is a bit of an offset to how each one sits on the head.
I've never seen it where the rocker arms tap them from the inside, but I am sure there are a few factors that could make that happen.
To me, I can spot the valve cover shape easy. So when I see them on a motor the wrong way, it sort of reminds me of someone wearing their shoes wrong
Post a picture for us...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-06-2010, 09:37 PM   #5
red71cheyenne
Back in the sticks
Here it is. Its coming thru on the inside of the drivers side!
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-06-2010, 09:41 PM   #6
71 super
71 super's Avatar
Yes they are side specific some are worse than others as far as fit. I had a set at one point that were cracked from the rockers rubbing them after a gasket swap.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-06-2010, 09:42 PM   #7
red71cheyenne
Back in the sticks
Here you can see where its pushing through.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-06-2010, 09:47 PM   #8
vectorit
What?
vectorit's Avatar
From your pic it looks like the pas side should be on the driver side with the PCV hole towards the radiator, and driver side should be moved over to the pas side with the oil cap towards the radiator.
That's my guess just from looking at the covers in your photo.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 07-06-2010, 09:59 PM   #9
stevencvn72
Kill Bill...et
I believe that those are on backwards too. You'll see that there's a definite high side and a low side on those. The high side should be closest to your carb. Yours are the other way. Hope it hasn't cracked from the rockers knocking on it, but from your description, it might be too late.
-Steve
I Grease
'67 Chev stepper
Old 07-06-2010, 10:03 PM   #10
red71cheyenne
Back in the sticks
Ok, so highest side in. I'll try swapping them and see if that corrects it. Just hope they won't leak all the time now. Thanks for the help guys.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-06-2010, 10:18 PM   #11
vectorit
What?
vectorit's Avatar
Unfortunately since your rocker(s) have worn a hole through, without welding or dare I say it - JB weld the little crack from the outside. The oil once it gets hot again will still leak out, maybe not as bad but enough to cause some sort of mess.
Those OEM style covers are pretty cheap from most of the vendors, I would plan on replacing those for a matched set of new ones when you get the spare cash.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 07-06-2010, 10:33 PM   #12
caminokid
Chevy nut
caminokid's Avatar
You can get a cheap set of chrome ones for I think 39.99.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 07-06-2010, 10:38 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Wish you were closer ive got 2 free sets on my wall identical to that lol. Sorry no shipping though. Give me a shout if your comming to TN though
John
1999 Toyota Tacoma 4x4
Old 07-06-2010, 10:41 PM   #14
sjarrett71
sjarrett71's Avatar
Wow, I've never seen that before and have learned something today. I love this board!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-06-2010, 11:25 PM   #15
red71cheyenne
Back in the sticks
Yep, I'll run them til I can't stand the leak anymore. Luckily they are cheap and easy to get. I too learned something. Would not have thought that they went on a certain way.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-07-2010, 03:17 AM   #16
raycow
Back in the good old days, the covers said "Chevrolet" on them and it was automatic that you would put them on so they read right side up. See what happens when GM tries to save a few cents by leaving the script off of the covers?
Ray
raycow is offline   Reply With Quote
