Old 07-06-2010, 06:39 PM   #1
andymarkv
Source for captured nut to mount arm rest?
The tabs are broken on the nut inside the door to screw the arm rest on.
Where can I get a replacement?
Pictures of nut;
andymarkv is offline   Reply With Quote
Old 07-06-2010, 06:47 PM   #2
john
member #16
john's Avatar
Re: Source for captured nut to mount arm rest?
Wes at http://www.classicheartbeat.com/ carries them.
john is offline   Reply With Quote
Old 07-06-2010, 07:27 PM   #3
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Fastenal also carries them:
http://www.fastenal.com/web/products...u=37973&ucst=t
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 07-06-2010, 08:08 PM   #4
andymarkv
Thanks guys!!
Old 07-06-2010, 08:14 PM   #5
mbgmike
We sell them but anyone who sells AUVECO products do to. Not hard to find
Here is on place
http://dixied.com/store/index.html
We are like $4.00 a pack of four
mbgmike is offline   Reply With Quote
Old 07-06-2010, 08:27 PM   #6
red71c10
The Red Menace
red71c10's Avatar
I had no idea replacements were available. I had a miserable time trying to use rusty ones from the wrecking yard! SONOFA!!! Oh well, shoulda asked the board!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 07-07-2010, 09:32 PM   #7
K2Orion
K2Orion's Avatar
I used my MIG to tack a regular hex nut in there. I guess that's what happens when you have a new MIG. You find reasons to use it.
K2Orion is offline   Reply With Quote
Old 07-07-2010, 10:24 PM   #8
hayhauler71
hayhauler71's Avatar
X2 on this one
hayhauler71 is offline   Reply With Quote
Old 07-06-2015, 01:09 AM   #9
rod1701
rod1701's Avatar
This may be a dumb question on an older thread but can the same parts be used to mount the door panels? The 4 screws along each bottom?
Mine were so badly rusted, only a couple came out. The other ones had to be drilled out or fell out of door with a little manipulation.
I tried a set of "HELP" series of license plate plastic pop in mounting tabs but a little too tight of a fit that didn't work. I could probably modify the plastic clip or the opening but since this is a patina truck, I didn't want to screw it up beyond repair in case someone decides to do a proper restoration in the future.
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 07-06-2015, 06:51 AM   #10
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
All you have to do is buy a license plate bolt set and use those plastic push square nuts that come with them they fit and work perfect , perfect size just snap them in and you are done
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 07-06-2015, 06:57 AM   #11
19673ontree
CAN'T FIX NOTHIN
I just read the previous post in this thread saying that the plastic license plate bolt snap in nuts were too tight yes they do fit tight but snap them in they will fit and it makes your screws fit real tight ive been using them for this purpose since the 80s never had a problem
underdash AC
Old 07-12-2015, 10:59 PM   #12
rod1701
rod1701's Avatar
Thanks guys. Maybe I was tired or just needed a little time and distance to rethink it. There are a couple of different plastic license plate nuts, one is a thicker plastic, and the other thinner. I bought what was on the HELP rack at the local PepBoys, which was thicker type. Couple of taps from the hammer and they popped in. Still with the springy part was too snug to pop back out for the screw to fit. Easy fix was to take a drill bit to open up the hole a little. Works perfectly now.
1979 C-10 LWB
