07-06-2010, 10:21 PM | #1 |
upper control arm stud part number? will this work?
Howdy folks,
First of all, the victim is my 69 chevy c-10 longbed that i am putting 84 suburban spindles, control arms, steering stuff, and brakes on. I yanked my old control arms to find that both of my upper control arm towers on my front crossmember were rotted out and needed to be replaced. i have a one-ton setup from a 78 or so truck so i yanked all the control arms etc to find that the towers were fine, but the member was heavily pitted and not as in good shape as my original. I am taking the towers from the 1 ton and bolting them to my original member, then bolting that to the frame(and drilling the required holes, etc of course.) My only problem is that the one-ton setup uses larger diameter studs. the 1/2 ton arms still go on and it seems that there would still be plenty of movement for alignment adjustment but i was wondering if anyone else has had experience with this. Also, one of the one-ton studs is kind of eaten away so i would like to replace it but i need a part number. Anyone have any idea what the part number for 1-ton studs is? Thanks for any help, tips, or suggestions! Mike |
07-12-2010, 06:41 PM | #2 |
Re: upper control arm stud part number? will this work?
has anyone tried running larger control arm studs just for the hell of it and can chime in and let me know if there were any problems?
07-12-2010, 07:50 PM | #3 |
At the body shop.
I think 1/2 tons use 1/2" stud. 3/4 and 1 tons use 9/16 studs i believe
" That didnt make it any newer " " Dont antique the equipment " |
