Future TOTM Winner
Auto to manual pedal assembly???
I'm considering swapping out my stock th350 for a manual tranny. I have the mechanics of it figured out, but I am still a little unsure about the pedal. How big of a PITA is it to add a the clutch pedal or do I have to change the whole assembly etc. I plan to adapt a hydrolic master cylinder to it, but I would like the actual pedal to mount and look stock. Any body have any pics?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Re: Auto to manual pedal assembly???
There was a thread on here not long ago with a very good pic from the shop manual. Anyway, your stock brake pedal shaft is hollow. The clutch pedal arm has a smaller shaft attached to it that goes through the hollow brake pedal shaft. The arm or lever for the pushrod clamps onto splines on the right end of the clutch pedal shaft and keeps it from sliding out.
Ray |
If you're interested, I've got a complete pedal assy, clutch, pressure plate, & SM465 out of a '73 that should fit. Although, the trans. bolt mount threads are oppisite between the '73 & up to '72. Everything's here in Orlando Fl.
A man's thoughts devise his ways; but it's GOD that directs his steps. |
#4 | |
Future TOTM Winner
Thanks, but this is for a 6.0 LS swap with a nv4500 and a hydraulic clutch setup.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 07-07-2010 at 03:32 PM. |
i have a complet pedal assembly out of a 72 still in the truck if your interested.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
#6 | |
![]() Join Date: Oct 2009
Thanks, Justin
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
