07-07-2010, 01:42 AM | #1 |
8 lug to 5 lug swap
looking for advice on easiest swap from 8 lug to 5
I have a 1970 3/4 ton 2wd wanting to lower and go to disc I'm thinking going with a 72 5 lug factory suspension and swapping it all in, other than I have coil rear. Is the frame the same so that i can just also get a factory leafs and brackets.. I'd like to stay with factory parts for eazz of getting replacements.. Thanks for your help. Also will anything from later 70's work or be clo0se enough to adapt. Fabrication is not a big deal odviously anything can be done with time but just looking for ideas. Thanks |
07-07-2010, 02:58 AM | #2 |
Re: 8 lug to 5 lug swap
The easiest swap for the front would be a 73-87 1/2 ton crossmember with everything left on it. This gives you 5 lug discs. You can also use 71-72, but that gives you the old style bushings which have to be greased.
On the rear, a 71-72 1/2 ton rear axle (also 5 lug) will bolt to your stock trailing arms. This would be a lot less work than a leaf spring swap. Ray |
07-13-2010, 11:56 PM | #3 | |
Thanks Ray |
07-14-2010, 02:07 AM | #4 | |
The 71 parts should bolt onto your 69 without any problems, but the rear end is about 1-1/2" wider. The control arm bushings will look just like the ones you have now, with grease fittings. They aren't difficult to grease, just kind of a nuisance. Also, you have to be careful about wiping up all the excess grease that oozes out or else the surrounding area will get pretty yucky looking after a while. Ray |
07-14-2010, 12:25 PM | #5 | |
Thanks Ray. |
07-14-2010, 01:13 PM | #6 | |
Ray |
07-15-2010, 01:45 AM | #7 | |
Thanks Ray. |
07-15-2010, 04:09 AM | #8 | |
Sure. Look at where the control arm shafts are bolted to the frame and just swap everything from the shafts on out. Ray |
