Bed longer than 8 feet
Just a quick question my long bed measures right around 100 inches which is obviously longer than 8 feet-
is my truck a longhorn? (think there called) the reason is when shopping for tonneau covers-bed carpet kits-replacement bed sides there all listed at 97 inches (if i can remember correctly)
1970 2wd ![]() ![]() ![]() |
Active Member
![]() Join Date: Oct 2002
Re: Bed longer than 8 feet
A Longhorn is 6" inches longer than the Longbed, so I think you do have one. 102" is it
depends on exactly how you are measureing// longhorns are pretty hard to mistake if you look at it write
Between Trucks...
A Longhorn will have a pretty noticeable seam towards the front of the bedsides.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 07-07-2010 at 07:23 PM. |
Rottenwood Garage Member
Here is a GMC that has the same bed as a Chevrolet Longhorn....notice the seam about 6" back from the cab. Also included is a longhorn bed on a dually frame.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
well my truck does not have any noticable seam like the truck above and ya it measures around 102" its a gmc also
it does also have the tool box on the side of the bed will it say anything on the options list on the inside of the glove box?
from this pic of your truck
![]() dont look like ya got a long horn but ya never know could have been blended in |
its all about the +6 inches
I suspect you are measuring the bed from the side, and on the outside at that.
Try measuring the inside of the bed. That's not a longhorn, and it obviously isn't a 9 foot stepside. The SPID won't tell you anything unless you can read model numbers. |
ok i was measuring from the outside i will try the inside
by the the way i guess measuring the inside is the correct way?
the published dimentions are measured on the inside.
ya i measured it on the inside-its Right on 8 ft now- (well another case closed) thanks for everyones input
