Old 07-07-2010, 11:01 AM   #1
355bullet
355bullet's Avatar
billet interior parts
i scored the whole billet kit for my truck, door panels are done.
Now working on the dash. I removed the dash last nite and i broke that center plastic piece that is inserted on the dash. It broke right where the vents go.
Does the billet piece go on top of that? that billet panel didn't come with instructions. whats the best way of installing it?
My truck has factory air, how do the vents work out?
my door panels
355bullet is offline   Reply With Quote
Old 07-07-2010, 11:06 AM   #2
maxxxy
maxxxy's Avatar
Re: billet interior parts
The long dash strip of billet that goes from about the middle of the dash to the passenger side, if it's an a/c correct piece, should have slits for the air to come out.
maxxxy is offline   Reply With Quote
Old 07-07-2010, 11:23 AM   #3
355bullet
355bullet's Avatar
yeah thats the one i have. So then do i remove the plastic long dash strip?
Then install the billet one? Or does the billet one go on top of plastic one.
(Like the gauges)
Old 07-07-2010, 11:28 AM   #4
maxxxy
maxxxy's Avatar
Is the gauges a sticker kind of? I'm pretty sure you pull off the plastic piece and screw in the billet piece.
Old 07-07-2010, 12:03 PM   #5
baclay9
The dash piece goes in place of the stock one
baclay9 is offline   Reply With Quote
Old 07-07-2010, 01:35 PM   #6
Low87
been here longer than Liz
Low87's Avatar
(Like the gauges)
I've tried it both ways, didn't like either. If you put it over the original plastic it doesn't fit right, even if you remove the "hooked" right side. If you remove the plastic trim & screw it into the rubber dash, it doesn't hold well. Maybe I've missed something obvious and there's a simpler way, if so please enlighten me because I like my billet.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 07-07-2010, 04:10 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
The one that I have on my truck mounted over the plastic dash insert. You have to break the plastic "Hook" part off, so that the billet piece sets into the groove, but if you get rid of everything else, then there is nothing to connect the vent pieces to behind the dash.
Frank
piecesparts is offline   Reply With Quote
Old 07-20-2010, 03:27 PM   #8
355bullet
355bullet's Avatar
i finally got around to working on my dash. Since i broke the original trim that holds the ac ducts, i bolted them to the dash. The billet trim still screws in place of the oem trim, but now im needing longer screws.(no biggie)
But that corner piece of the dash worked out after all. I used a heat gun on the corner of the dash. Once that was really hot i placed the billet trim on top to re-shaped it the corner. Second time i applied heat on the dash, again i placed and applied pressure to that corner. But this time used a cold wet towel to cool it off. This time it stayed to shape.
Cool thing is i can make sure the ducts are sealed correctly for the ac before i install the billet trim
Ill up load some pics tonite...
Old 05-17-2011, 07:55 AM   #9
sumran
sumran's Avatar
I am fighting the same issues with mine. I do not have enough room for the billet strip to fit properly. I will need to trim away a small amount of the dash padding material for the strip to fit. That is ok because I am putting on a dash cover on that Stitch made for me.
The other issue with the install is the vent duct work. The screw hole for the billet attachment is in the center of the vent. If it hits the duct box in the middle, there is a reinforcement web that will need to be removed.
I'll post some pictures of the process and the end result when I get it installed.
None of these obstacles are a big deal but they would do well to install a few of these and provide some installation tips.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 05-17-2011, 05:46 PM   #10
Tezjoe84
Tezjoe84's Avatar
I don't know if this will help... this is how I solved my problem. I had some screw holes that didn't line up, so I just cut some small pieces of steel strips and drilled them for the screws.
Here's some pics of what I had to do... it's not pretty... but worked for me.
Joe
1957 Chevy 3100 Stepside
Tezjoe84 is offline   Reply With Quote
Old 04-21-2012, 03:15 AM   #11
cmax87v3500
cmax87v3500's Avatar
when my dad installed it on his truck, he said he used speed clips on the vents somehow and used the screws that hold the billet dash panel into that groove and that clamped the dash in between the vents and the billet, giving it a nut and bolt affect. the factory passenger side dash trim is NOT supposed to be in place when installing the billet, it replaces it. that held it firmly in place, and the part around the gauges goes over the stock piece. hope this helps, every billet inerior pieces ive seen install like this.
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
Old 04-21-2012, 08:48 AM   #12
piecesparts
The one I installed in my truck had th eplastic piece still on the dash. The part that went around the corner of the end in front of the passenger was to be trimmed off, to allow for fitment at the point. Mine has been on for years and I have no problems with it.
Frank
