wood removal
What is the best way to get the wood out of the bed?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
![]() Join Date: Sep 2007
Re: wood removal
that sounds like the beginnings of a baaaad joke!!
1967custom |
Re: wood removal
mine fell out.....was easy
Re: wood removal
haha! yeah that could be taken in about a thousand directions lol!
#16876
Re: wood removal
My most recent one was rotten. I took it off of the truck and braced it up on its side. I beat the wood out and used an angle grinder to cut the remaining bolts. I'll try to find some pictures for you. Don't bother trying to salvage the steel strips. They are cheaply and easliy replaces.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
Re: wood removal
all the wood beds i've had were filled with holes and rotted wood . just wakin the wood with a claw hammer removed it and an angle grinder with cutoff wheel to get the old metal remnenants out and to clean up the crossills and perimeter angles
Re: wood removal
My wooden bed came apart in about a full day of using a grinder with a c utoff wheel... a lot of swearing, and banged up knuckles.
But seriously the cutoff wheel and grinder was the easiest way of taking it apart. 75% of the carriage bolts did not want to let that bed go. |
Re: wood removal
im sure that im gunna have to use an angle grinder because my bed floor is reall in good shape but it still needs replaced
#9 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: wood removal
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: wood removal
well the anwser for wandering minds is duck tape it down
Re: wood removal
I assume that you are talking about the wood bed itself, not a load of firewood!!
![]() To remove the entire bed Just remove the bolts with the offset washers... If you are removing just the wood then leave pieces under the outer edges and wheel wells. The cross sills remain on the frame unless the entire bed is coming off. Here pics of my bed removal. maybe they will shed some light for you...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 07-08-2010 at 06:34 AM. |
