wheel size
Looking for aftermarket wheels for my 60 half ton stepside GMC. It has 6 lugs. Most offerings are 6 1/2 inch bolt patern. Is this correct for my truck? Thanks in advance.
actually in my haste, i made an error. The ones i've seen offered are 5.5 inch, not 6 1/2. Last edited by skysoldier173rd; 07-07-2010 at 09:42 PM. |
Re: wheel size
Yes Sir that is correct!
Grandpas and Dads and now my 1965 C-10 1975 SWB C-10 |
Re: wheel size
It should be 6 on 5-1/2". There is an 8 on 6-1/2" for 3/4 and 1 ton trucks, so whoever wrote the ad you saw might have gotten the two confused.
Ray |
#4 | |
Re: wheel size
Re: wheel size
now that i got the size, i'm wondering about backspacing. Just looking, it appears there's a lot of room for wide tires, but I'd like to know for sure. What's about the max back spacing rim width the stepsides can handle without altering anything?
#6 | |
Re: wheel size
I suggest looking through some of the various picture threads. Save some pics of trucks you like the look of here to give us an idea of what works for you.
Re: wheel size
One more thing to consider is the center hole size, I purchased some late model wheels, and the center hole is too small, I ended up having a mechinest making them bigger.
