02-18-2003, 10:09 AM | #1 |
welding on rearend?
is it ok to weld on the rear axle with everything intact? i did some work to my trailing arms straitening them out and now my pinion angle is off. i want to cut my axle saddles off and reweld them in a better position. is this ok? thanks
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
02-18-2003, 10:24 AM | #2 |
Mike
I would be careful as to how much heat you apply.Skip your welds from side to side so it dn't warp the tubes.I've welded spring perches without any problems
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
02-18-2003, 10:30 AM | #3 |
Fabricate till you "puke"
2 nd that, take you time & keep the heat down. if you can run a mig on it it will be less heat than the old stick welder also. Another thought, you should be able to get wedge shims to change the angle ....good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
