Old 07-07-2010, 11:34 PM   #1
68K30
Modifying Suburban doors to fit a pickup
Have any of you swapped pickup door tops (window frames) on to Suburban doors? I have a pair of rust free original 1970 Suburban doors tha I have no use for and my truck needs doors, any help would be appreciated.
PS, Sorry for the double post, I was not paying attention and first posted this in the parts section.
68K30 is offline   Reply With Quote
Old 07-07-2010, 11:37 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Modifying Suburban doors to fit a pickup
I think burb doors are worth a little more than pickup doors. I would have to believe you could make a straight swap, or probably sell them for more than you could get your truck doors for. A lot less work that way.
If you become a subscriber you can post a Wanted to Trade in the classifieds, or even just outright sell the doors.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-10-2010, 12:07 AM   #3
68K30
Anybody??
Old 07-10-2010, 09:49 AM   #4
1956cameo
1956cameo's Avatar
Truck doors are easy to find, burb doors are not. I would swap them out for truck doors at the next swap meet and walk away with a little extra money as well. That bieng said if you want to convert the burb doors over then I would drill out the spot welds on the door shell to the outer door channel. If you do that it should pull out. I would practice on the rusty truck doors and see if it will work. I have never done it but if I were to try that is the first route I would try. Good luck!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 07-11-2010, 12:47 AM   #5
68K30
Thank you.
Old 07-11-2010, 12:52 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Where you're located, I can understand your dilemma. I grew up in NY and a "rust free anything" was hard to find.
Not 100% on this, but as stated above, there should be two spot welds (front and rear) and then there's a bead along the top (again front and rear), drill and grind those out and they *should* come out. Take a close look, you should see what I mean.
Mount your doors back on the truck, (take measurements BEFORE you take them out ) and you can "tweak" them for a real nice fit before final welding. Don't forget, depending on how you put them in, you can "tweak" them "in or out" compared to the cab/drip rail. Make sure your vent window and side windows fit and work well, then weld 'em back up tight.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-11-2010, 08:44 AM   #7
trucks72
trucks72
trucks72's Avatar
I have swapped the tops before on them. I have on at the shop that I did that to. I will take a picture monday of it. As for the sub door worth more, I could sell 100 truck doors to 1 sub door. There is not alot of demand for them.
trucks72 is offline   Reply With Quote
Old 07-12-2010, 04:37 PM   #8
trucks72
trucks72
trucks72's Avatar
pictures
Old 07-12-2010, 11:01 PM   #9
68K30
Thanks again.
