Old 07-08-2010, 12:26 AM   #1
workinprogress67
brake line question
i am going to buy a ss brake line kit for my 67 shortbed from lmc and im not sure(neither is lmc) if the kit comes disc/drum as pictured. Can i buy a 72shortbed kit since they came disc/drum? Are all of the rear lines the same?
all help appreciated,thanks
workinprogress67 is offline   Reply With Quote
Old 07-08-2010, 06:44 AM   #2
raycow
Re: brake line question
The 72 rear axle is about 1-1/2" wider than the 67. I expect the lines for the axle will be about that much too long in total.
Ray
raycow is offline   Reply With Quote
Old 07-08-2010, 11:47 AM   #3
swierker
swierker's Avatar
I would check the site venders (GMC Pauls) specifically. They are quite a bit cheaper than LMC.
swierker is offline   Reply With Quote
Old 07-08-2010, 11:53 AM   #4
DPowers
DPowers's Avatar
I agree about the site vendors.
Or either one of these:
http://www.getdiscbrakes.com/RightStuff/Default.aspx
http://www.inlinetube.com/
DPowers is offline   Reply With Quote
Old 07-08-2010, 12:52 PM   #5
71tahoe
71tahoe's Avatar
LMCs stainless transmission lines are from inline tube. I suspect the brake lines are too.
Another difference on the disc brake front lines is that the fittings are different size side to side for the brake hoses.
71tahoe is offline   Reply With Quote
Old 07-08-2010, 01:26 PM   #6
Alvin
Never Done?
Alvin's Avatar
I bought a 72 brake line kit from inlinetube for my 68 that was disc/drum. Wound up not being able to use it because the front lines on the 72 ran to the front of the crossmember, while on my 68 they needed to run across the rear of the crossmember. I had to buy a complete set of 68 disc brake conversion lines from inlinetube to get the correct fit. The 72 line set is still sitting in the garage
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
