07-08-2010, 12:44 AM | #1 |
Inline six shroud?
I am trying to find s shroud for my truck I have an inline six in my 70 chevy short bed c-10 anyone know where I can find one??
'70 Chevy Shorty I support our troops!! Thank You to all that have served!! |
07-08-2010, 08:52 AM | #2 |
Junior Member
Re: Inline six shroud?
I have never seen a shroud on a stock inline 6 setup. There is just a protective plate above the fan for safety.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-08-2010, 08:53 AM | #3 |
'70 C-10 Primer
My 70, didn't have a shroud. I bought a chrome universal one several years ago, but can't remember where.
"The difference between stupidity and genius is that genius has its limits." Albert Einstein |
07-08-2010, 12:45 PM | #4 | |
Its a Truck Thing......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
07-08-2010, 12:47 PM | #5 |
All I have ever seen is just a metal plate on top of the radiator.
I have one for sale if interested.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
07-08-2010, 09:26 PM | #6 |
I have a nice stainless steel plate on top right now I am just trying to find something that will help cool my motor better.
07-08-2010, 10:06 PM | #7 |
Junior Member
What temperature is your engine running? What fan does your engine have?
The 250 inline 6 in my '67 will set and idle and never get over 190, it has an after market temperature gage. The fan on my engine is a 4 blade fixed, no clutch.
07-08-2010, 11:13 PM | #8 |
I have a stock guage in my truck and and it is in the Hot!! after the truck werms up.
I also have a new cam and headers and an intake allong with a holley 2brl carb on it so it is going to run a littla hotter, I did put a clutch fan on it that is 18inches in diameter.
07-09-2010, 07:08 AM | #9 |
Some six cylinders did have a fan shroud, but I think it's only if the truck came originally with an automatic transmission. Mine had one, it was a 250 six with a 350 turbo trans, it looked just like one found on a small block truck, but the opening was off set to one side.
07-09-2010, 09:59 AM | #10 |
Humm...
Very interesting!
07-09-2010, 10:25 AM | #11 | |
Try changing thermostats? I'm not sure how much cooler it'd run with a shroud. Might have to go with a better radiator (V-8 4 row) http://www.lmctruck.com/icatalog/cb/full.aspx?Page=125 or maybe even electric fans. Last edited by dnorris009; 07-09-2010 at 10:27 AM. |
07-09-2010, 12:17 PM | #12 | |
Junior Member
07-09-2010, 11:13 PM | #13 |
Tot Roddin'
My '69 also had a shroud on it (all original) as it ran a 250 backed by a 2spd powerglide.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-09-2010, 11:46 PM | #14 |
My truck used to run hot as well. I have the same engine. My problem turned out to be that the cylinder head had been over machined. New head and problem solved. You might try changing head gaskets and having the head checked by your local machine shop if you can. Or try changing to a lower temperature thermostat. Or easier yet, you can buy some Water Wetter or Purple Ice from Summit Racing or your local parts store. I would only use this option as a last resort. It should stay cool with no additives. Maybe check your water pump too. To do this, crank up your truck with the radiator cap off and wait until it warms up. You should see water circulating. Hope one of these things solves your problem.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
07-10-2010, 12:34 AM | #15 |
It only has a dual core radiator not a four, but I moved the clutch fan closer to the radiator hoping that it might pick up the heat faster, so I will know soon after I finish butting my new throtle pedal on it.
Thank You everyone for your advice.
