Old 07-08-2010, 12:53 AM   #1
Contagious209
Won't start
Ok here's what happened. I had to move the truck so as I turn the key it gets stuck in the start position and I can hear the starter engaging after it turned on. So I quickly turn it off. Then I turn the key forward again and it turns on fine. Well after I shut it off I moved it again so as I turn the key to turn it on it wouldn't do anything. The key will go forward and back like something is loose but nothing is happening. So I removed the steering wheel to see if I can find something broken but I can't seem to find nothing. I think it's the key switch but my dad said it's not. Any ideas? I tried the search function but didn't find nothing. Any inputs?
1973 custom delux 20 with 454 project
2000 dodge neon
Contagious209 is offline   Reply With Quote
Old 07-08-2010, 10:37 AM   #2
Chlsnk
Chlsnk's Avatar
Re: Won't start
Sound like the pot metal rack broke real common.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 07-08-2010, 10:50 AM   #3
Contagious209
Re: Won't start
So new steering column should fix this?
2000 dodge neon
Old 07-08-2010, 10:56 AM   #4
Chlsnk
Chlsnk's Avatar
Re: Won't start
yep IMHO replacing the pot metal rack and selector isn't worth the work .I just replaces the column and that is a piece of cake.
