Old 07-08-2010, 08:39 AM   #1
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
C-20 to K-20 body swap
Thought I would share my current project, that I finally started. Have had the parts for over a year.
Started out with this.
And this past Tuesday started the frame swap. Enjoy
Now just to find time to get the drive train installed.
Drive train will be 5.3/4L60E/NP241 ( NP241 is from a 90 burban )
bowtieguy79 is offline   Reply With Quote
Old 07-08-2010, 07:37 PM   #2
82chevy350
82chevy350's Avatar
Re: C-20 to K-20 body swap
Looks Good
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 07-08-2010, 07:41 PM   #3
doc70sub
doc70sub's Avatar
nice work....
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 07-08-2010, 07:49 PM   #4
Schwinn68
Schwinn68's Avatar
you made that look too easy!
Ben
_____________________________________
1971 Chevy shortbed 350/4-speed sold
2005 Chevy Duramax EC/4x4
Local 597 Pipefitters
certified TIG MIG and stick welder
Schwinn68 is offline   Reply With Quote
Old 07-08-2010, 08:05 PM   #5
bowtieguy79
Ephesians 2:8
It looks pretty easy in pics doesn't it! Proves that you can do just about anything with a good cherry picker!
Old 07-08-2010, 10:44 PM   #6
DBLSPRT68
DBLSPRT68's Avatar
I did a C10 to C20 body swap several years ago with a cherry picker also By MYSELF! On a Patio behind my house. How redneck is that!! Now, I have a 24X30 shop for my second body swap coming up this winter. This time it'll be a breeze
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 07-09-2010, 10:18 PM   #7
bowtieguy79
Ephesians 2:8
Mans got to do what a mans got to do!!! It got the job done didn't it. We did this in a 24x36 garage 8ft ceilings.
Old 07-10-2010, 10:19 AM   #8
68 TT
Still plays with trucks
68 TT's Avatar
I did the body swap on my 67 C10 to K10 conversion with the cherry picker bolted into the bed of my K20 in my back yard by myself. Works pretty good, just wish I had a 2-car+ garage to work in to finish the job.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-14-2010, 10:25 PM   #9
bowtieguy79
Ephesians 2:8
Got it home, and started doing some more prep work.
Trying to see if I can retain the AC location from the LS engine. Made my own mounts, seems to be working ok. Need to adjust the motor mounts at the frame, it doesn't want to sit down in the mounts like it should.
Old 09-15-2010, 01:19 AM   #10
355bullet
355bullet's Avatar
nice swap!
looks good with the hubcaps,,real sleeper
355bullet is offline   Reply With Quote
Old 09-15-2010, 08:12 PM   #11
Davidmichael
Davidmichael's Avatar
awesome job so far!
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 09-15-2010, 09:12 PM   #12
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
What size rims and tires are on the 4x4 frame?
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 09-15-2010, 09:48 PM   #13
bowtieguy79
Ephesians 2:8
As the truck sits now it has 16" stock wheels with 305-75-16's
Old 09-24-2010, 09:42 PM   #14
bowtieguy79
Ephesians 2:8
It currently has the engine and trans between the frame rails as well as the double din Delco CD player installed. Making progress slow but sure!
Old 09-24-2010, 09:53 PM   #15
Davidmichael
I always wondered what one of those factory CD players would look like installed.
01 S10 ZR2
Old 09-24-2010, 09:54 PM   #16
palposity
palposity's Avatar
So did you have to install a body lift to accommodate for the difference in the 2wd and 4wd tranny hump in the cab?
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 09-24-2010, 10:11 PM   #17
bowtieguy79
Ephesians 2:8
Nope, I should have added these pics in Still need to do a little metal work, but this should work.... gotta love plasma cutters!
Old 09-24-2010, 10:45 PM   #18
3r!c84
Badass
3r!c84's Avatar
looking good what size motor is that? 6.0?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-25-2010, 06:24 PM   #19
palposity
palposity's Avatar
Got it. I had to swap out the tranny hump in my truck too.
Old 09-25-2010, 09:42 PM   #20
bowtieguy79
Ephesians 2:8
nope just a little 5.3L It was cheap and available. Wanted to run a 6.0 but there is always next time right!
Old 09-27-2010, 01:08 PM   #21
48cj2a
48cj2a's Avatar
Looking good - You have me about convinced to quit looking for a diesel replacement.
Need to stop by and see this some time and pick your brain.
Since I'm still picking parts would I be better off picking up a TBI harness on the firewall side since mine is a diesel to make this hook up easier?
What Tranny and T/C you going to use? Got the 400/208 now.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 09-27-2010, 03:21 PM   #22
68 TT
68 TT's Avatar
The 5.3 is no slouch plus they are easy to come by if you blow one up. Not so with a 6.0 engine.
With a cam, headers and a good tune a 5.3 will make over 360 hp to the rear wheels.
Add in a 70 mm turbo and an intercooler with a Z06 Vette cam and it will make low 600's to the rear wheels with a stock bottom end and unported heads.
Old 09-28-2010, 03:02 PM   #23
48cj2a
48cj2a's Avatar
Any cross member issues?
03 Suburban Z71 Z71
Old 09-30-2010, 10:00 PM   #24
bowtieguy79
Ephesians 2:8
Define issues? All I have to do is re-drill all four holes. Other wise the mount is the same as the 4L60E adapter as well as a 700R4.
I heave ho'd the transfer case in tonight. Then had to pull it back down once I saw the gasket laying on the bench.... DOH... So on the second attempt its mounted. I was able to measure for shafts tonight. Plan to visit a buddy's stash and see if I can find a close fit.
And for the record, YES the NP241(27spline) mounts directly to the tail end of the 4L60E with no issues!
Old 09-30-2010, 10:07 PM   #25
48cj2a
48cj2a's Avatar
I meant the front cross member...can you post some pictures of the front cross member clearances
Did you use the 700R4/NP241 adapter then too?
03 Suburban Z71 Z71
