Old 07-08-2010, 10:17 AM   #1
ubtripn
ubtripn's Avatar
Changing 350 Intake Manifold Gasket - Best Gasket/Sealant?
Hey guys,
I broke off 1 intake manifold bolt yesterday so I will be pulling the whole thing today and need to know what is the best gasket/sealant combination to use for the best seal on an intake manifold for a Chevy 350? Also, what is the best sealant to use on the bolts? Is black Permutex high temp silicone good? Thx in advance for the help.
ubtripn is offline   Reply With Quote
Old 07-08-2010, 11:27 AM   #2
cdowns
cdowns's Avatar
Re: Changing 350 Intake Manifold Gasket - Best Gasket/Sealant?
like i told you in your pther post sillycone is a pisspoor thread sealant// pull your bolts you tried sealing with sillycone and you will see little to no sillycone is on the actual threaded surface
read my post for proper thread sealant
Old 07-08-2010, 11:37 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
I've always used oil resistant RTV as a thread sealant with no problems. Maybe I'll look into getting some "proper" thread sealant, but it's worked for me so far.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-08-2010, 12:09 PM   #4
ubtripn
ubtripn's Avatar
Thanks CDowns, I had noted it. Just looking for the general opinion from everyone.
Old 07-08-2010, 12:18 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Just double checked, Edelbrock actually recommends RTV as a thread sealant for intake bolts.
http://www.edelbrock.com/automotive_.../2000/2101.pdf
Beat it to fit,
Old 07-08-2010, 12:36 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
you got to love the old Room Temperature Vulcanization........How many of you knew thats what RTV stood for???? Be honest...
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-08-2010, 09:19 PM   #7
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
ARP makes a very good teflon based thread sealer
One of the issues with RTV is it throws off the torque value if you use a torque wrench
I like a product called the right stuff from permtex - this stuff is the best sealent I have ever used
If you disassemble something that you have stuck on with the right stuff be prepared to use a wire brush on a drill to clean it off - the stuff is just plain tough
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 07-08-2010, 09:22 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Any sealant you use is going to throw off the torque compared to dry. If Edelbrock recommends RTV, that's what I'll use. Seems to work.
Beat it to fit,
Old 07-08-2010, 09:47 PM   #9
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
i used permatex ultra Grey. soft yet solid!
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
