Old 07-08-2010, 03:08 PM   #1
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
2" Drop Shackles in the '72 Over the 4th Weekend
Well this weekend my Dad and I dropped the rear end of the truck 3" by putting in 2" drop shackles from Frank's Pick'em Ups, and removing the spring overloads on the springpack.
The diff is pretty greasy... this winter it will be yarded out of there and an Eaton Posi-traction unit with new gears will be installed. Maybe even disc brakes.
1. Removed the upper shackle bolt out of the old shackle.
2. New 2" drop shackle being held up for comparison.
3. Dad spraying lube on the shackle bolts.
4. New 2" drop shackle installed.
5. Impact wrench on the old U-bolts.
6. Same deal...
7. After removing old U-bolts... 40 years have taken it's toll. The threads basically flaked off... since we were taking out a 1" overload spring, we needed the threads.
8. Clamping the springpack together to remove the center pin bolt.
9. More of same...
10. Center pins were a little rusty too.
11. Also removed heavy duty coilover rear spring/shocks along with overloads.
12. Went in to Tacoma, WA to Right Way Spring Co, and had a set of new shackle bolts custom made. Since nobody stocks them in a auto parts store. Also got new pins for the leaf packs.
13. There is a little plastic "anti squeak" pad that goes between the axle pearch and the leaf pack.
14. Installing new pins in leaf packs (minus the overloads).
15. new center pin installed.
16. tightening the new center pin.
17. New U-bolts setting in place.
18. Installing lower axle clamp and nuts on u-bolts. You can see new $25 dollar parts store Monroe shocks hanging from upper mount.
19. Cutting off excess bolt thread on the pins with a sawzall.
20. Rear end snugged up and new shocks installed...
21. New stance... 3" lower in rear... left front stock until the rear settles, and then will lower front later...
Here is a few shots of my '72 GMC and my dad's '70 Chevy. The ET slots that are on my truck were originally on my dad's with adapters since his truck is 6 lug. It was cool to get them from him and polish them up and install them on my truck. He bought his '70 in 1974.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-08-2010, 05:10 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 2" Drop Shackles in the '72 Over the 4th Weekend
love it man!
John
1999 Toyota Tacoma 4x4
Old 07-08-2010, 06:19 PM   #3
Southcity
Southcity's Avatar
Nice work, your truck looks great and great step-by-step shots, thanks for sharing. Don't dump those spare parts........
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 07-08-2010, 06:24 PM   #4
GASoline71
GASoline71's Avatar
Thanks you guys...
I've still got the stock shackles and overloads. But those coilovers were shot. Those went to the scrap yard.
Gary
Old 07-08-2010, 06:29 PM   #5
Southcity
Southcity's Avatar
You held on to the stuff that matters for sure. Forgot to mention that your dads truck looks good too. What are your plans for the front suspension?
Old 07-08-2010, 06:35 PM   #6
GASoline71
GASoline71's Avatar
The front is still just a hair lower than the rear. It rides completely different now. More better for sure. So I will prolly do a 1" to the front. But don't know if that will rake it too much.
Eventually, I will get 3" drop springs in the rear for a total of 5", then do a 2 1/2" drop spindle in the front.
Gary
Old 07-08-2010, 06:47 PM   #7
bigguy69
dazed and confused
bigguy69's Avatar
looks great! both of them!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 07-09-2010, 01:18 PM   #8
GASoline71
GASoline71's Avatar
Thanks again you guys...
Gary
Old 07-09-2010, 03:13 PM   #9
splehigh
splehigh's Avatar
Nice trucks! I love those slots.
splehigh is offline   Reply With Quote
Old 07-10-2010, 11:05 AM   #10
packrat42
packrat42's Avatar
Looks good!!
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 08-20-2010, 09:43 AM   #11
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Found it Gary.....
Do you have any troubles with the leaves hitting the bed or making loud noise? Do you have contact info for Franks?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-20-2010, 12:42 PM   #12
RCbowtie69
RCbowtie69's Avatar
nice trucks
RCbowtie69 is offline   Reply With Quote
Old 09-08-2011, 01:28 PM   #13
hpurey
Gary
Sorry, I know this is an old thread but it is exactly what I was looking for.
Anyhow, the pics are no longer showing and was wondering if you still had them.
Hazen
hpurey is offline   Reply With Quote
