rolling the rear fender lip
Does anybody have any advise on tucking in the inside lip on a step side rear fender so that I will have a little more rear tier clearance?
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: rolling the rear fender lip
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
jack up the the side your doing,,,slip a Wood Baseball bat in between the tire and the wheel opening...slowly , carefully roll the tire with the bat rolling the lip till you have it as far as you need.....
I have used the baseball bat method many times when I used to work at a tire store & have done it on my 66. Start with a smaller diameter section of a wood bat that barely fits between the tire & wheel well. Hold the bat at about a 60 degree angle & have someone slowly drive the car forward & backward allowing the bat to roll. Use larger section of the bat after several rolls. Two items to consider: 1- Do not use this method if you have chrome wheel well openings. 2- This will get only about 3/4" of extra clearance but the inner lip will be smooth & won't cut your tire if it should rub.
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Senior Enthusiast
Thanks for sharing that link. I never knew anything like that existed. Clever idea and looks like it would work well on the right type of fender.
I went on ebay and rented one it was about 60.00 buck after a 260.00 deposit but I got it right back, they work awesome do a search on youtube fender roller you'll see
