Old 07-08-2010, 06:01 PM   #1
CaptHutch66
Ooops! Wonder what that costs?
CaptHutch66's Avatar
Loose tilt steering head/knuckle
Hey guys hope everyone had a great 4th!! Need some help with getting this part of my steering column out/off. I've reviewed the previous posts and looked at the chevytalk guys how to but it dosen't address my column. (keyless). I think I need to use the wheel puller and pull this section out to gain access to the loose bolts (one of which I can see through the tilt spring hole, is about to fall out) but I'm unsure if I need to remove the funky nut on the column or if it will pull over it. If I need to remove the nut 1st what do you use as it has several facets on it unlike a regular nut. Thanks in advance, Hutch
Hutch.....Metro Atl Fireman 29 years
1952 GMC 228 w/4spd Hydra Matic (SOLD)
1966 GMC stepside Shrtbed...350 w/Turbo 350 auto
CaptHutch66 is offline   Reply With Quote
Old 07-08-2010, 09:15 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Loose tilt steering head/knuckle
http://www.gnttype.org/techarea/susp..._steering.html http://www.chevyasylum.com/column/tiltcol.html
http://www.superchevy.com/tech/sucp_...umn/index.html
Just a few I found Capt...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-09-2010, 05:59 PM   #3
CaptHutch66
Thanks Rich. Mine is a keyless column. I finally figured out I had to pull the metal housing off to get to the hinge pins. Ended up using the bolts from a deadbolt for the hinge pin removal. Thanks have a great one, Hutch
