Old 07-08-2010, 07:30 PM   #1
Russ65C10
Russ65C10's Avatar
Got a problem need to find out how to deal with it
So I put my "new" hood on my truck today and when tightening up the bolts one of the "nuts" broke loose and now I can't finish tightening it. Any ideas on how to get to it with out messing up the hood????
Russ65C10 is offline   Reply With Quote
Old 07-08-2010, 07:38 PM   #2
mbgmike
Re: Got a problem need to find out how to deal with it
I would use a small die grinder with cutoff wheel. I wouldn.t use a sawzall type saw.
mbgmike is offline   Reply With Quote
Old 07-08-2010, 07:44 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
If you an loosen the bolts and remove them, try Permatex U-weld epoxy to glue the nut back in place. We did this on a Crown Vic hood and it worked well.
Old 07-08-2010, 07:57 PM   #4
hossmann
hossmann's Avatar
take the hood back off flip it over cut a square shape around the hole weld the nut back and then the square piece and reinstall
66 chevy lwb 355/400
hossmann is offline   Reply With Quote
