07-09-2010, 11:25 PM | #1 |
Sofa King Crazy!!
Truck P/S Bracket?
Quick question. Is this a power steering bracket from a 71-72 Chevy truck? If so why won't my belts line up? I purchased the correct power steering pump and the pulley fits correctly so it must be a bracket issue I'm guessing??? I am doing a conversion on a 67 with a 327, maybe the pulley should be cone shaped?
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
07-09-2010, 11:42 PM | #2 | ||
"I ain't nobody, dork."
Re: Truck P/S Bracket?
I'm at work until 10:30 PST. When I get home I can take a pic of my 1972 GMC P/S pump and bracket. Also the pulleys... engine is a 350.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-09-2010, 11:47 PM | #3 |
IIRC the pulley should have 2 to 3 inches of dish to push the belt out from the pump.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
07-10-2010, 12:00 AM | #4 |
Between Trucks...
I think the pulleys for AC and non/AC trucks are different. I'm dealing with this issue myself.
Beat it to fit, Paint it to match... |
07-10-2010, 01:03 AM | #5 |
Most of the time when you buy water pumps from auto zone they don't have the flange pressed on correctly. That throws your pulleys out of alignment. This happened to me last year.
07-10-2010, 01:23 AM | #6 | |||
Sofa King Crazy!!
Sounds feasable, but the body of the ps pump is long and the shaft is only about an inch and a half with the threads. This is what leads me to beleive the bracket could be off of a Chevy van, newer Chevy truck or something else. It is about half an inch out of alignment and everything looks correct on the pump, this is what makes me think it's the bracket.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 07-10-2010 at 01:27 AM. |
07-10-2010, 11:47 AM | #7 |
Sofa King Crazy!!
ttt
07-10-2010, 11:50 AM | #8 |
VA72C10
all of the ps pulleys I have ever seen are straight with no dish.....really think it's a bracket issue.
Looking for a 67-72 swb or blazer project in or around VA. |
07-10-2010, 12:01 PM | #9 |
Champagne Taste on Beer Budget
Okay these are off my '72 Pickup.
While not the best pics they might help a little. Good luck!
Coming Soon: Project 1970 Country Truck |
07-10-2010, 02:17 PM | #10 | ||
Sorry that I'm a little tardy getting these up for you. I worked 2 hours of overtime last night. Didn't get home till almost 1am.
Here ya go... Also you can see my front soft plug is leaking... GRRRRRR... wish there was an easy fix... Gary
07-10-2010, 03:41 PM | #11 |
Sofa King Crazy!!
Thanks!!!! That bracket is definitely different from mine it is flush against the block, unlike mine. This is probably the issue. Now to buy one and powdercoat it to make it look nice and shiney! Thanks C20 and Gasoline!!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 07-10-2010 at 03:46 PM. |
07-10-2010, 04:50 PM | #12 |
YIKES!
Next to GASoline71's, mine looks terrible! Oh well it will be nice and clean one of these days. Just hope it helped between the two of these pics.
07-10-2010, 05:25 PM | #13 | |||
Mine is actually "dirty"... Gary
07-10-2010, 07:05 PM | #14 |
In your third pic, it looks like I see some coolant in that freeze plug.
Hope your not leaking!!!
07-10-2010, 09:44 PM | #15 | ||
It started seeping about 6 months ago... sucks bigtime. first time I have ever had a freeze plug leak on an engine I have built. I would have to pull the steering pump out to get to it. Thought about some sort of sealer like "aluma-seal" but not sure if that would even work...
Gary
07-16-2010, 10:59 AM | #16 |
Sofa King Crazy!!
Ok, here we go again. I purchased an OE factory P/S bracket, $82 after tax, and it STILL does not line up with the other pulleys. Looks like I have one of maybe two options.
1. I could put on a coned pulley and that may get it back that extra 3/4 of and inch but I can only find multiple belt pulleys. 2. I have a 2 peice crank pulley that I could put washers in between them and it would move the outer most pulley forward. Any other ideas?!?!?!?!?
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 07-16-2010 at 11:01 AM. |
07-16-2010, 11:07 AM | #17 |
Between Trucks...
Got a pic?
07-16-2010, 03:06 PM | #18 |
here are some pics in progress on my conversion. all the parts and pulleys were purchased on d'bay. my water pump and crank pulley line up good. my alt. is about a belt width off, as well as the ps pump is about a belt width too. i seem to have enough wiggle room to shim both into position.
07-16-2010, 03:39 PM | #19 |
Between Trucks...
That bracket looks different then the stock one I pulled off of mine. Pulley doesn't look that far off in your pics, but probably off enough to throw the belt. I'm running an Alan Grove PS pump bracket and a pulley from Summit. My pulley sits in too close, it's running on the middle groove of the crank pulley.
07-18-2010, 01:53 AM | #20 |
Sofa King Crazy!!
I purchased the 2 groove pulley and it is coned a little so I'll try that tomorrow. I like those alluminuminum pulleys, may go that route later.
