Old 07-10-2010, 12:27 PM   #1
1972CST
1972CST's Avatar
Top removal?
I want to pull the top on my blazer but im not sure if I can yet. I have installed all new poly body bushings but my rocker boxes are completely rusted out. My pass side rocker panel and floor are solid but the drivers side is in bad shape. If I pull the top now am I gonna run into major problems? I know every blazer on here w/ the top off isnt 100% restored or pristine original condition. Thanks for your help...
1972CST is offline   Reply With Quote
Old 07-10-2010, 02:39 PM   #2
elliotbradley
elliotbradley's Avatar
Re: Top removal?
I'd be worried that your body will start to sag and fold in half if you opened the doors with no top and no torsion boxes.
elliotbradley is offline   Reply With Quote
Old 07-11-2010, 07:09 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Top removal?
New mounts are good. There are other trucks on the board with rusted out torsion boxes running topless. If you're just going to be driving around the streets, you'll probably get a little sag and maybe have some door bind if you part on an unlevel surface. You'll probably also have a hard time putting the top back on.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-13-2010, 08:42 PM   #4
1972CST
1972CST's Avatar
Re: Top removal?
Looks like im not goin topless anytime soon... im too afraid of door binding issues. I was hoping there was someone on here who had the guts to try it and tell me to go for it. Oh well. Maybe next spring I will have my repairs done and can join the rest of yall havin a blast with the top off.
Old 07-13-2010, 11:40 PM   #5
bouncytruck
SKINNY TIRES RULE!
Re: Top removal?
Go for it! Like I said, there are other trucks on the board running topless with rusted out rocker boxes.
bouncytruck 1972 K5
Old 07-14-2010, 10:55 AM   #6
litebulblsc
litebulblsc's Avatar
Re: Top removal?
My top doesn't fit do to sagging, and I am still able to open and close the doors. Mine sat without the top bolted, driver side door open, and front clip off it for 10 years. Body bushings are gone, bu I bet the metal around them is too. And like I said, my doors still open and close.
litebulblsc is offline   Reply With Quote
Old 07-15-2010, 02:50 AM   #7
13lazer
13lazers' blazers
13lazer's Avatar
Re: Top removal?
i think you will be ok with the top off, the frame carries the body. unless your body mounts are rotted away.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 07-15-2010, 08:37 PM   #8
1972CST
1972CST's Avatar
Re: Top removal?
If I decide to pull the top off and things go crazy will I be able to get it back to the point it is now (doors work good and gaps are nice)? Fear of the unknown is crippling!
Old 07-16-2010, 11:28 AM   #9
RARA
RARA's Avatar
Re: Top removal?
I Have never had my hard top on in 3 yrs since I got my 70 blazer. The tortion boxes have rot and the body mounts are original (shot). I only use a soft top. The doors only bind if I am on a really uneaven surface like one wheel parked on a hill, but it goes right back if I move the truck. The PO filled the tortion boxes with spary in insulation or tuff stuff. I think thats a dumb thing to do, but it may have stiffened it a little??? Take the top off if you are not doing offroad antics its the way the blazer is meant to be.
RARA is offline   Reply With Quote
