02-18-2003, 05:40 PM | #1 |
Rally Wheels
I've got a 71 K10 and I'm try to find a set of stock wheels for it. Does anyone know what years will be compatable? I'm being told there was a change in stud diameter around 74. Thanks.
02-18-2003, 06:54 PM | #2 |
Roadtrip!
wheels
I have a 70 k-10 that i had the newer style rally wheels on (6 lug) they fit ok but the rear axle shaft was very tight to the center hole of the wheel. The wheels i had were 73 and newer 15x8.
02-18-2003, 09:58 PM | #3 |
Now the others dig........
I had the same problems with my wheel shaft in the rear with my rallys, but a little grinding here an there on the rim with a file just a bit will clear it up, It might take a while though.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
02-18-2003, 10:02 PM | #4 |
Too bad you weren't closer. I have some I'd be willing to part with.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
02-18-2003, 10:48 PM | #5 |
Gotta Startem Early
I have a set of 5, 6 lug, 4 of them have the chevy hubcaps, 16", tires are pretty new, they came with the truck when I bought it. They were trying to make it seem like is was worth more than what I paid for it. I am in TX though.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
02-18-2003, 11:06 PM | #6 |
Adamls, thanks for the response and the pics. You're right, Texas is a long way away from California and at this point I don't see myself heading that way in the near future. What I'm really after is a set of 15" six lugs that a local wrecking yard has. However they're telling me that there might be a difference in lug stud diameter starting in 73 or 74. I would like to get all the information I can before I go after those wheels.
02-18-2003, 11:08 PM | #7 |
Gotta Startem Early
Sorry I couldnt help, but if it doesnt work out or get out my way look me up.
02-19-2003, 12:10 AM | #8 |
I have a set of 4- 6 lug 15x8s with rings and centers..2 rims are mounted with newish 245x60s
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA Last edited by bigjimzlll; 02-19-2003 at 12:12 AM. |
02-19-2003, 12:11 AM | #9 |
heres one with the mounted tire on it
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
02-19-2003, 12:21 AM | #10 |
senior member
www.petepaulsen.com has tons of vintage wheels check him out other wise go to the auto wreckers
69 GMC bagged |
