Old 07-10-2010, 01:48 PM   #1
K30cummins
K30cummins's Avatar
bedliner fitment???????
anyone with a 73-87 that has installed a later model bedliner in it wondering witch would be closest to fit
K30cummins is offline   Reply With Quote
Old 07-10-2010, 03:19 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: bedliner fitment???????
A rubber mat or the plastic liner
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-10-2010, 07:50 PM   #3
tucsonjwt
Not sure if you are asking to install a bedliner for a later model truck that would intentionally not match your bed? If you are asking for a recommendation for a bedliner, I would go with a bedrug. Covers the gap between the tailgate and the bed and cushions the load. Downside is it leaves tiny bits of wood chips in the fibers when you haul plywood or osb, and it does hold the moisture for a while after it rains - just like wet carpet.
tucsonjwt is offline   Reply With Quote
