Old 07-10-2010, 10:22 PM   #1
70cst
70cst's Avatar
Keyed Fuel Line Block-Anyone have info?
I am lookin for a source for a Keyed Fuel Line Block...Corvettes use these as a theft deterent system. You have a key...which when turned in the block... will block the gas in the line so if someone tries to steal your truck they will not go very far before they run out of fuel. Anyone with info? I have googled but no luck so far. Maybe I am using the wrong term.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-10-2010, 10:45 PM   #2
mpauly
Re: Keyed Fuel Line Block-Anyone have info?
Not sure I've ever heard of such a keyed fuel block. Couple theft deterrent options:
- inline fuel solenoid with a remote switch (basically a modern version of what you mentioned the old corvettes having)
- if you have an electric fuel pump, wire a kill switch
- electrical kill switch (won't be able to start the engine at all)
- brake line lock (can start engine, but can't move)
Michael
mpauly is offline   Reply With Quote
Old 07-10-2010, 10:59 PM   #3
Shane
Shane's Avatar
most stolen cars are carried off on a roll back nowadays ...
Shane is offline   Reply With Quote
Old 07-11-2010, 09:34 AM   #4
ATT
ATT's Avatar
My dad bought one several years ago. I will check with him to see where he ordered it from.
ATT is offline   Reply With Quote
Old 07-11-2010, 01:09 PM   #5
70cst
70cst's Avatar
Thanks...Greatly appreciated.
Old 07-11-2010, 10:12 PM   #6
70cst
70cst's Avatar
Still lookin...
Old 07-12-2010, 08:09 AM   #7
70cst
70cst's Avatar
Anyone???
Old 07-12-2010, 08:47 AM   #8
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I think I found something you might be interested in I Hope
My bad I just read your post again an your looking for something non electrical to put inline on the fuel hose itself correct..
http://www.holley.com/HiOctn/ProdLin.../15650NOS.html
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-12-2010, 09:02 AM   #9
petey-pablo
"THE GREEN GOBLIN"
Heres a different type .
http://cgi.ebay.com/UNIVERSAL-IN-LIN...item1e5b7bd513
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 07-12-2010, 10:00 AM   #10
70cst
70cst's Avatar
Hey we are getting closer. I have done a lot of googling and I see reference to this sort of set up but no leads. So they do exist so I will eventually find what I quest.
Old 07-12-2010, 10:29 AM   #11
70cst
70cst's Avatar
http://www.steinertractor.com/JDS106...the-carburetor
Well I am getting closer.
Old 07-12-2010, 12:10 PM   #12
hotrod100
hotrod100's Avatar
You could use one of these along with the electric key switch that Petey-Pablo posted.
http://www.dan-marc.com/79-afc173.html
My build thread.
hotrod100 is offline   Reply With Quote
Old 07-13-2010, 10:00 AM   #13
70cst
70cst's Avatar
Thanks all for your replies....
Old 07-13-2010, 12:53 PM   #14
ATT
ATT's Avatar
I finally found the one my Dad got. But I was wrong its not for the fuel it goes inline with the brakes to lock them. It is made by Hydraulic Interlock Systems in cape coral Florida 941-772-4490. Works with a key, Park then push the brake pedal turn the key and pull it out. The brakes will hold pressure so you can not even roll the vehical.
Old 07-13-2010, 11:28 PM   #15
70cst
70cst's Avatar
Thanks for the update ATT ...
Old 07-14-2010, 12:26 AM   #16
vectorit
What?
vectorit's Avatar
Instead of splicing into your fuel line with something that could wear out prematurely, and causing a breakdown in a place that would not be good/safe.
Have you thought about just removing the mechanical fuel pump, and then installing a quality electric fuel pump then putting a switch in to cut the power to that pump? At the same time you could also work it out in that switch to cut power to the starter?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
