Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-11-2010, 01:15 AM   #1
ozzie50
s10 rear end question
I am doing a 1950 s10 swap (the s10 was wrecked not tearing down a perfectly good truck). In order to do this I have to used a 4x4 rear end. Are any parts of the 2wheel drive interchangeable. I can get a housing but not sure about the condition of the gears. Could I use my internal workings on the 4wheel drive? The 2 wheel drive rear end was rebuilt a couple of years ago.
ozzie50 is offline   Reply With Quote
Old 07-12-2010, 12:00 AM   #2
Damien
Damien's Avatar
Re: s10 rear end question
I think the rears are the same other then the width as long as you are not using a 8.5" rear.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 07-12-2010, 01:39 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Is the axel from a ZR2 - 4X4? If so, it's a completely different beast. All other 4X2 and 4X4 used the same rearends. A little more information would be helpful.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-12-2010, 08:30 PM   #4
Damien
Damien's Avatar
The rear axle from a 2x4 is narrower then a 4x4. I remembered after I had laid in the mud and paid for the axle shafts.
Old 07-13-2010, 04:50 AM   #5
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
and some 8.5" ring gear and some 7.65" ring gears, if its the same ring size the internerals will all work. axle length varries. could always get a 8.8 out of an explorer for it too.. a little tougher rear and usually pretty cheap too, good way to go disk brakes if you go new enough rear
www.car-parts.com find one there I got a stock 3.73 posi complete with disk setup and the yoke for 125
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 07-15-2010, 09:49 PM   #6
chevyndn
if you go new enough on the blazer rearends you can get disk brakes too.
chevyndn is offline   Reply With Quote
