Nothing like a little rust repair!
This is my first stab at rust repair. The truck was free so I'm putting in the work. Replacing all four cab supports, lower door pillars (front & rear), cab corners, front and rear floor panels and will eventually get to the inner roof. I know it's a ton of work and I could have gone with another cab but the truck was free and I think i have the skills to do the job right. Coming along nicely so far.
Re: Nothing like a little rust repair!
i had to do the same,looks great turned out clean....good job and more pics as you go plz!
Impressive!
R/ Billy
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
wow! and that's nothing like a "LITTLE" rust repair...
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
![]() ![]() Join Date: Nov 2008
You're right, you DO have the chops to do the repairs. Very impressive. You're basically cutting away the entire bottom and replacing it; to be followed by cuttng away half the top and replacing it. Woulda been easier to just bolt the doors onto a new cab but what fun would that have been? Lol. How many hours do you think it'll take you beginning to end?
Nice work!
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Wow i'm jealous.... not of the cab but of your skills lol.
Very nice work, my truck was the same price, and I am starting pretty much the same project, hopefully mine turns out half this good
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
Restoration Virgin!
Although it doesn't seem you need the practice....why not just put in a new floor??....Nice work!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
landarts
![]() Join Date: May 2005
I am doing the same repairs right now. All of your fabrication looks great . I have the same welder as you, what settings are you using , and what size wire?
I did a rocker panel and am about to do the cab corner in my 64. You are braver than I am! Looks like it's coming together nicely though!
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
I am always amazed at the skills of the people on this forum. The trucks that have been brought back from the DEAD. In Arizona we would call that scrap, still a lot of rust free cabs in the southwest.
#13 | |
#14 |
#15 | |
Restoration Virgin!
![]() keep us posted on the progress!!!.... and by the way.... ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 07-12-2010 at 09:53 PM. |
#16 | |
#17 |
Looking good, I've got two trucks to look forward to doing that too. I didn't figure yall'd have that bad of rust problems in Georgia. They use so much road salt around here in the winters. I know of trucks that've been fixed 2 to 3 times, not because of quality of work but because of rust caused by the salt! Welcome to the rust belt! I just wanta get mine running for starters then go from there one at a time LOL!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#18 | |
#19 |
Done a lot of metal work....Nice Job.
A lot to think about, not much to worry about... |
#20 |
You didn't use any bracing? Nice work.
#21 |
Nope didn't brace anything and maybe I should have. It will just be a little more work down the road. The passenger side was pretty much rusted out anyway so if things were going to move they had already done it. The driver side is still intact and I've taken some measurements and both sides are pretty close. Before I weld the rear lower door pillar to the outer floor pan I will triple check my measurements (comparing them to the drivers side) and just take my time constantly checking my fit with the doors.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
#22 |
ENGINE BUILDER
Looks good to me. Take your time and you will be proud of your results!
JIM ZAG |
#23 |
Resident Lurker
Any updates?
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252 "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken |
#24 |
![]() Join Date: Jul 2002
Awesome work!!!! Did you have the doors on when you welded the rockers? Let us know if you run into any problems with that..?? Thanks...Patch
Patch |
#25 |
One day.....
Very nice!!! Keep up the good work.
DZL1. |
